1st -> clutch in -> 2nd -> *CRUNCH* -> clutch out -> WTF???
Starting from a standstill, I accelerate semi-hard revving it up to probably 5k, then I see that I have to avoid an oncoming car at the intersection, so I do a REALLY quick shift and slam it to 2nd, and right as I'm entering the gate (BEFORE I let the clutch out), I hear a CRUNCH noise and feel some resistance/vibration through the shifter.
I'm thinking there's no way it can be grinding a gear since I didn't even clutch out yet.
I've been driving stick for 5 years and have never grinded, so I don't even know how griding is supposed to sound.
Actually, to give a good description/feel of it, I would say it felt like shifting into Reverse while the car is still rolling forward a bit.
So is that the synchros?
The good news is the tranny felt fine afterwards.
2006, 6MT, 17k miles if it makes a difference.
Someone stole "My Garage"
Pretty much everyone I know with a 6MT TSX experiences the "crunchy" 1-2 shift. You only really get it when shifting quickly, and my guess is yes, the synchros have to do a lot of work between 1-2 because the gear ratios are very far apart on those two gears.
If you do a slight pause in between 1 and 2, you'll avoid the crunch altogether.
Oh, and with a short shifter (like me), you get the crunch more often unless you really try to space the 1-2 shift out mentally.
I don't get the crunch at all and I have the 04 6MT. Just takes some getting used to and as curls said, a millisecond more of a pause between gears. I also noticed more smooth engagement with new tranny fluid.
Originally Posted by psteng19
Well, it's reassuring to hear that I'm not the only experiencing this "crunch" during the 1->2 shift.
I noticed that with this car, shifting into reverse while the car is still moving grinds the gears. I dont remember that happening with the other mt that i used to drive, unless i was high on something the whole time. I miss not having to fully stop to put it in reverse, just a little.
That's going to happen in any car. If the car is moving, the counter shaft which is always spinning with the wheels, no matter what you do with the clutch, is going to be moving. Reverse involves a sliding a straight cut gear over to engage the drive shaft. This third shaft is always connected to the counter shaft and means that if the wheels are moving forward, the third shaft is moving in the opposite direction of the drive shaft. It's just a straight cut gear (that's why reverse is so whiny), there's no synchro, so if the wheels are moving, it's going grind the flat edges of the gears together until the teeth slip together with an unhealthy clunk.
Moral of the story, don't be moving, especially forward, when you shift into reverse.
![Ponder](https://acurazine.com/forums/images/smilies/ponder.gif)
My 1-2 shift has been iffy since day one, especially when the transmission is cold.
It's worst downshifting into 2nd on a turn (I don't double-clutch - typically I clutch just before the turn and shift into 2nd just afterwards), and also, paradoxically, seems rougher the more conservative I'm driving. Shifting 1-2 at 3000 RPM = rough. Shifting 1-2 at 4000 RPM = drops right it.
I think there is some drag on the input shaft even with the clutch in -- even shifts into 5th and 6th don't feel very smooth at first. After I've been driving a few minutes, it gets much better.
![Shrug](https://acurazine.com/forums/images/smilies/shrug.gif)
Originally Posted by Mskierki
There are a few automobiles that utilize a syncro for the reverse gear.
I know that some VWs have one.
This is true - I believe most 5MT cars use reverse syncros with helical cut gears. With a 5MT there is an open spot in the 5th gear linkage for a syncrod reverse on the input/output shafts. In a 6MT there has to be a whole additional linkage to the transmission, an unsychronized straight cut is probably the cheapest, easiest, and lightest way to have reverse.
The higher the revs, the smoother the shift for these.
But, I don't want to argue with the great and knowledgeable Icculus.
Driver/Detailer
We get a new Honda MTF here in Australia. We used to get them in bottles labelled Honda MTF Plus, made in USA. The new ones are Honda MTF 06 and made in Australia. The fluid itself is grey in colour, not golden anymore. It helps a lot with the 1-2 shift.
I am not quite sure what you are saying here. I don't see what a whole other linkage has to do with the 6th gear and the type of cut on the reverse gear.
Haha nice, I'm flattered. What I mean is (if in fact I am correct), There are two gears per linkage (back and forth on the stick), with an existing linkage its easy to incorporate a reverse constant mesh helical gear in the open slot, which would not make the whining sound and engage smoothly with synchronizers. With a whole new linkage that has to be added for a reverse gear when there's a sixth, the easiest thing to do is to add an unsynchronized straight cut gear. This is probably the approach Honda took just trying to keep the cost down.
I've never seen a reverse gear work any other way than what I described (straight cut gear that slides axially) though it wouldn't be surprising that Alpha Romero decided to do it differently, just to be different.
I also don't really understand why you would want a syncho on the reverse. How often are you going to be shifting into reverse while on the move? I'm not saying they don't exist, I just don't see why you would bother.
It makes it easier and smoother to shift into gear. Just like the syncros on forward gears 1-6.
They are comparatively uncommon, but not unusual on high-end cars equipped with manual transmissions.
The Audi S4 had one a few years ago... (http://www.audiworld.com/model/s4/01/specs.shtml)
But neither gear should be spinning when you're shifting into reverse. 1st through 6th have synchros because the gears (well, dogs) are spinning at different rates. The synchros bring the speeds together so it doesn't catch suddenly when the dogs engage.
SidhuSaaB
05-30-2020 12:40 AM
