07 TSX rattle
07 TSX rattle
I've read a lot about the different rattles in the TSX but I haven't seen anything about the one I have.
I have an 07 with about 16,000 miles on it and I just recently noticed a very metallic sounding rattle coming from the front drivers side. You can only hear it with the windows down and only when going over bumps. I haven't taken it to the dealer yet, i wanted to see if anyone else has this problem.
It almost sounds like the muffler is loose. But I had a friend/mechanic look under the car and nothing obvious was loose.
Has anyone else had this problem?
Thanks.
Thanks.
Thanks.
Thanks.
We have an 05 TSX and started having that same problem a while back. I've done mechanic work all my life on the side and inspected every possible thing from head to toe on that car and couldn't find anything wrong from underneath and the top. Then one day I was replacing the air filter and looked down at the bracket holding the battery down. I tried to wiggle it and it wasn't super tight but did move a little. I thought to myself - this can't be causing the problem but put some threadlocker on the nuts and tightened it up. NO NOISE since doing this simple fix. Just thought I would share.
Brad
Brad
i have the same problem on my 08. its a rattling sound and sounds like its coming from the the window, possibly from the seatbelt. nothing seems to be loose but i dont know. if any of you guys go the dealer plz share because im just having a little hard time getting to them.
I've got the plastic rattle noise from the passenger side A-pillar and could not get it fixed after 2 dealer visits. The annoying part is the same problem could not be reproduced at the dealers side even a mechanic was sitting next to me during a test drive. I applied this fix suggested by this service bulletin http://www.tsobad.com/jtso/Misc/04-042.pdf but problem persists. It is super annoying and really makes me feel selling my 07 TSX with only 9600 miles on it. Any suggestion is appreciated.
Oliver!!!
mlody
12-04-2019 02:11 PM
GWEEDOspeedo
01-15-2016 10:39 PM
