07 TL Switchblade Program Problems
I did the 07 TL Key Mod for the 04 TSX. When programming the key, I went through the correct procedures to program all three key fobs by. The two original TSX key fobs work perfectly find, I can unlock, lock, and open the trunk. On the the 07 TL key, I can only lock and open the trunk. For some reason I can't unlock the doors.
What do you guys think the problem is? I don't think the immobilizer was damaged. And when I press the unlock key, the red led blinks, but just doesn't unlock the doors. This is an 07 TL Memory 1 key too. Thanks for any help or suggestions.
Actually, I just figured it out. All i had to do was once programmed, I held down the lock and unlock buttons at the same time. This flashes a repeated led. Then I held it again for one long led flash. What this did was reset the key. After that, everything worked perfectly fine.
Thanks for the suggestions and help. Hopefully this helps other that are doing this mod.
SidhuSaaB
May 30, 2020 12:40 AM
joflewbyu2
Oct 8, 2015 11:16 AM
... any other suggestions?
