06 TSX Shifting Problem
Old Apr 9, 2007 | 09:21 PM
cjserio's Avatar
4th Gear
I have a 2006 TSX 5AT and i have just about 6k miles on it. In the morning when I drive to work, there is a huge hesitation when shifting from first to second. The car shifts out of first and then there's a delay for a full second, then it shifts into 1st gear but it really slams into 2nd and the car jerks.
It only does it on the first shift of the morning....after that it's fine for the rest of the day and if i step on the gas harder than usual it doesn't hesitate. Only if i'm going a bit slow coming out of my driveway.
Has anyone else experienced this? Is this something I should be concerned about?
Thanks,
Chris
Old Apr 9, 2007 | 09:35 PM
dolparism's Avatar
It's Honda's worst technology "Drive-By-Wire"..... DBW on AT is ok...but it does not work on MT.....
one of main reason we drive MT is.....Mt gives morfe precise control, better response, and etc......
anyway don't concern it.....u will get use to drive without jerking.....but not precise like cable.....
Old Apr 10, 2007 | 01:09 AM
RaCeR4LiFe022's Avatar
ehh i had a uncomfortable shift from 1st to 2nd until i got my ground wires which helped that alot.. so much that my mom said o wow your car is running smoother lately
Old Apr 10, 2007 | 05:41 AM
cjserio's Avatar
4th Gear
Mind explaining what that means?
Chris
Old Apr 10, 2007 | 08:18 AM
bluexcrush's Avatar
get grounding kit
Old Apr 10, 2007 | 12:30 PM
cjserio's Avatar
4th Gear
What does a grounding kit have to do with my transmission not shifting smoothly the first shift of the morning?
Chris
Old Apr 11, 2007 | 01:16 AM
aaronng's Avatar
Driver/Detailer
The transmission fluid is till cold and circulating. Does this happen during hot summer days too?
Old Apr 12, 2007 | 06:22 AM
cjserio's Avatar
4th Gear
I haven't owned it during the summer. I just got it in October. That sounds like a very likely explanation though the car is garaged and it's not really that cold out when it happens....maybe 30-40. There's far worse climates than New England. Just wondering why not everyone has the problem if that's the case.
Old Apr 17, 2007 | 06:50 PM
Deepfreezed's Avatar
Acura TSX 2004 5AT
mine does the same thing and it has 61K.
cold does have something to do with this though
Old Apr 17, 2007 | 07:26 PM
Daffunda's Avatar
Get it fixed. That is not normal.
Old Apr 20, 2007 | 02:30 PM
TriniBwoy's Avatar
Nothing's wrong with you car...it's perfectly fine. The fluid is a bit cold so that's why the car behaves that way. After it warms up a bit and is circulating more it should be fine. If it was shifting that way all the time, then you'll have a problem.
cycdaniel
Dec 17, 2019 10:58 AM
JDMVP
1G TL (1996-1998)
Sep 17, 2015 06:14 PM
kuzdu
Sep 10, 2015 08:42 PM
Mike Bertram
Sep 10, 2015 09:27 AM
HeloDown
Sep 8, 2015 06:51 PM
