'06: Squeaking when rolling down windows
Old Jun 5, 2006 | 10:12 AM
defjukie's Avatar
Title says most of it.
I get a pretty awful squeaking/squealing sound when rolling down my windows (particularly the front windows). I just started noticing it a couple weeks ago, I just go the car 4-5 months ago.
I've tried searching but came up empty. Is this a common problem?
Gonna see if I can get htis fixed @ the dealer, and maybe get them to throw some felt on the inside while they're at it!
Old Jun 5, 2006 | 08:43 PM
xacepro57x's Avatar
I have that same sound too..I thought it was b/c of my window tint as it happened right after that..go figure..
Old Jun 6, 2006 | 06:05 AM
defjukie's Avatar
hmm that sucks, cuz they're probably going to try + blame it on your tint.
Old Jun 6, 2006 | 09:18 AM
poleish1's Avatar
try cleaning in between the cracks. i had the same problem, so i rolled the windows down and cleaned the the strip and it really made a difference. its been awhile now and the squeak has come back. so i checked the window again, and there is more dirt/dust in there. goodluck. (i think cleaning the contact points will also reduce the scratches that our tsx are prone to)
Old Jul 12, 2006 | 12:34 AM
mjtsx's Avatar
I have this problem also. When in the neighborhood, I took the car to the dealer. The service fellow sprayed the window guides with silicone. That quieted the windows for a couple of hours, but they're back to their squeaking ways. If anyone finds a permanent solution, I'm interested!
Old Aug 7, 2006 | 02:08 PM
ckiggins's Avatar
Anyone find a solution yet? This one started on my driver's side window this weekend. Only happens when the window goes down...no problem when putting the window up.
Old Aug 7, 2006 | 02:14 PM
Knox's Avatar
Advanced.
Mine went away after the tint was installed.
Old Aug 7, 2006 | 02:20 PM
Newplay1's Avatar
08 MDX with Sports
Mine only happens to my driver side window and going down about 3/4 or half way mark.. sound like a old piece of junk car/windows rolling down and up..
Old Aug 7, 2006 | 06:17 PM
mjtsx's Avatar
I carefully cleaned all four windows from inside the car with Windex and the noise is gone. I used to hear it, like everyone else, while the windows were lowering. What this means to me is that the dealer was wrong, and that my problem, at least, has nothing to do with the lubrication of the guides on the sides of the window. I think it was dirt on the inside of the window going past the seal between the window and the door. We'll see how long the quiet lasts.
Old Aug 13, 2006 | 12:28 AM
driver centric's Avatar
I Know Right?
Anyone else have any success fixing this issue? My windows have started to get really noisy in the past week. I think I need to give the glass and seals a good cleaning and hopefully the noise will stay away for a while.
Old Aug 13, 2006 | 12:34 AM
PWPTSX's Avatar
i had an 06 and had the same problem after 3 months of ownership. the way i found easy to clean them is to spray water in between the window and the rubber pieces (the water stream gotta be somehow fast so that it will clean it...........), try doing that when you wash your car! for me it works
Old Aug 13, 2006 | 09:41 AM
I Know Right?
Thanks PWP, I'll try that next time I wash it.
Old Aug 13, 2006 | 05:33 PM
I Know Right?
Went over all the windows with glass cleaner today. I also cleaned the seals and weatherstripping, no luck. Both front windows are still very noisy when going down.
Both also sporadically make a loud squeak noise when sealing at the top (letting the window up) or when breaking from that seal (letting the window down). I'm calling my dealer to schedule an appointment tomorow. Fingers crossed.
Old Aug 14, 2006 | 07:42 AM
jwood_06TSX's Avatar
As did mine!! I had the moleskin put on presto, it is now gone!! Now i just need to find a place that will inspect me in the philly area.....anyone know of any?
Old Aug 16, 2006 | 09:27 PM
Dr Gong's Avatar
I had the same problem and it went away when I used a Rainx cloth on all the windows. Helps keep the window clean also!
Old Aug 17, 2006 | 10:08 PM
I Know Right?
Rainx cloth eh? Did you use it inside and out or just outside? I might have to look into that.
I made an appointment with my dealer to have them look at the windows on the 26th. I'll report back with results.
Old Aug 19, 2006 | 02:50 PM
Dr Gong's Avatar
I used the Rainx on the outside only. I cleaned the inside with Windex. I had cleaned in and out with Windex before though, so I'm pretty sure it's the Rainx that worked.
Old Aug 19, 2006 | 09:35 PM
helraiser's Avatar
My passenger side window squeaks and leaves some crazy streaks on it, not impressed.
Old Aug 20, 2006 | 10:31 AM
I Know Right?
That's how mine started but now the driver's side does it too.
I haven't had a chance to try the rain-x yet but I'm hoping it does the trick.
Old Aug 20, 2006 | 11:11 PM
achan268888's Avatar
window motor noise
i know how you feel. i got both front window motor and regulators replaced. noise is gone but mainly the blk rubber channels where window up and down needs to clean when you wash your car. it is blk dust.
Old Aug 25, 2006 | 10:38 PM
mjtsx's Avatar
That was exactly what mine (all four) were doing. It's been three weeks or so since the thorough cleaning and the windows are still quiet. If the problem does return, I'll prolly try the rain-x cloths, since the windex was pretty messy.
Old Aug 26, 2006 | 10:26 AM
jerzpwr's Avatar
my 06 loaner had this same exact problem
Old Aug 26, 2006 | 10:49 AM
I Know Right?
Mine is at the dealer now, hopefully they find a fix for the issue.
Old Aug 30, 2006 | 09:37 PM
toddf's Avatar
7th Gear
My 06 makes the same exact noise. It's awful -- like fingernails on a chalkboard.
I believe the problem is with the horizontal rubber seal at the bottom of the window.
Makes my Acura sound like a POS Yugo.
Old Aug 30, 2006 | 11:12 PM
helraiser's Avatar
The streaks I'm getting are on the inside of the window. My driver side started squeaking this weekend after a 1000km trip. It was horrible cuz I wasn't expecting it. Thought I was back in elementary and teacher was trying to calm us down.
I washed the car and the squeak didn't go away, even a day later. Now a fewhours in the sun and it doesn't squeak. WTF?! I smell another TSB
Old Aug 31, 2006 | 09:14 AM
jerzpwr's Avatar
i guess this is pretty common on the new 06s because the two 06 loaners i had had the same problem.. really annoying
Old Aug 31, 2006 | 12:21 PM
ntwin98's Avatar
8th Gear
mines does it also but only after i wash my car. then a couple of days later the noise stops. im thinking of printing this and bringing this to the dealer.
Old Aug 31, 2006 | 12:38 PM
Ishakir's Avatar
Same problem with my 2006. Did the dealership come up with anything?
Old Aug 31, 2006 | 06:40 PM
I Know Right?
All my dealer did was clean the windows and the tracks inside the door. It seems to have solved the problem for the most part....but who knows for how long?
Old Sep 7, 2006 | 09:53 PM
junktionfet's Avatar
Mine does the same thing on all four windows, intermittently. I keep the glass clean and I even used some dry lube in the glass channels, to no avail. I'll have the dealer check it out next time it's there.
Old Sep 8, 2006 | 02:21 AM
user 46466648's Avatar
My '04 does the same thing, but for me it seems to be temperature dependant. The only other thing I have is that the auto up does not always work as it should.
Old Sep 8, 2006 | 04:20 AM
dwest1023's Avatar
My tsx is 6 month old and I have yet to have this problem. I have not used my windows that much nor do I drive it much. Maybe that it why Idon't have the problem? Are there any other 06 TSX owners without the problem?
Old Sep 11, 2006 | 02:13 PM
silverback's Avatar
7th Gear
Hiya, I have this sound too on my '06 after about 2 months. This is too common to be a fluke. The Rainx wipe on the outside or cleaning the ribber seems to be the temporary solution, right?
Old Sep 11, 2006 | 05:48 PM
Teh_Cow_Jr's Avatar
^ That seems like the only temporary solution. I bought some stoners invisible glass to try to get rid of the squeeking, but i haven't had time to use it.. :/ Hopefully it'll remove the squeeking..
Old Sep 12, 2006 | 10:09 AM
Kismet's Avatar
Dela-where-ean
Been lurking for awhile but I'd also like to add that I have the same problem. Mostly on the driver side door, the other windows are intermittent. '06, 2 months old. 6k miles and haven't changed the oil yet... pretty scary when it says:
"-300 miles, service overdue"
Old Sep 12, 2006 | 10:14 AM
tsxdriver's Avatar
is glad to be back!
i have a squeak too except mine is when my front drivers side window is half-way down and when it's completely up. i'm taking my car in on friday cause i also have some other squeaks/rattles in the cabin
Old Sep 13, 2006 | 11:31 AM
lucid-dream's Avatar
I have an 06 and it has the same exact problem, the two from windows make a very loud squeaking noise when rolled down. I am going to take it in to the dealer when I need the next oil change.
Old Sep 13, 2006 | 11:56 AM
puiyingbread's Avatar
mine said "970km, service overdue"
60miles =around 100km correct me if i am wrong
so i got almost 600mile overdue........
u still gd to go..........
and yes, i got the window problem too !!!!!
took it to the dealer already but they only clean the windows and lub. the track,
and they tested and said it was ok, but when i got my car , i lower my windows immediatly, guess wt i heard, haha, sounds still here.........i was like wt the fxxk, then i went in again and talk to them and book another appointment again...........
Old Sep 18, 2006 | 01:46 PM
silverback's Avatar
7th Gear
Lads, I vacuumed the felt at the bottom of the window. No worries since, but then again the problem was intermittant so I can't say for sure if this fixed/helped. I don't have squeaking now anyway. My analytical mind says this is a DIRT issue. The window seals so nice on the highway, that I'd say the fit is quite tight and prone to any debris logding between horizontal felt and window.
Old Sep 20, 2006 | 12:52 AM
A Cake On's Avatar
OEM plus!
I get the same thing on my 05. The noise it makes rivals some of the most annoying sounds I have ever heard. It mostly does it on the driver side window when using the auto down feature. Sometime the passenger window does it too but not as often. I am going to try giving the rubber trim a good cleaning and see what happens.
