05 Compression test numbers
Old Aug 18, 2011 | 12:05 PM
pimpshit's Avatar
6th Gear
Was wondering about a rough idle so i pulled the plugs and this is what i got
1=190
2=180
3=190
4=195
miles 123,000
I know 2 is lower then all the others but does anyone think that would cause a steering wheel/seat shaking rough idle?
Old Aug 20, 2011 | 05:43 PM
nigelboyne's Avatar
engine mount a bad shock maybe a half shaft, is yours an auto or manual
Old Aug 20, 2011 | 09:49 PM
green_henry's Avatar
How old are your plugs? Out of sheer boredom and frivolous experimentation, I have already replaced mine twice, and the car ran noticeably smoother.
Old Aug 20, 2011 | 10:57 PM
I hate cars's Avatar
Compression numbers are fine. Generally if they're over 100psi there's enough compression to fire at idle without a misfire. That doesn't mean everything is fine, it just means you won't have a misfire due to compression. Did all plugs look the same?
Old Aug 21, 2011 | 05:02 PM
LuvMyTSX's Avatar
Do you have a CEL? O2 sensors seem to go often on these cars and I believe can cause a rough idle. There are several threads about this as well.
joflewbyu2
Aug 18, 2019 10:38 PM
emailnatec
29
Sep 28, 2018 04:27 PM
jterp7
3G MDX (2014-2020)
Feb 3, 2016 08:34 PM
MilanoRedDashR
Oct 2, 2015 10:49 AM
saturno_v
Sep 27, 2015 08:13 AM
