Door hold brackets squeaking
Old Aug 15, 2011 | 08:09 PM
Wernerjp's Avatar
4th Gear
Unhappy Door hold brackets squeaking
On each door there is a thin metal bar that keeps the doors open from partial to half full and then fully open. These bars are in the middle between each set of hinges. The rear door bars started to squeak when opening and closing the doors - I put some high temp grease on these bars but it only lasts several weeks and then the doors start squeaking again. Any suggestions?
Old Aug 16, 2011 | 07:45 AM
cman219's Avatar
I have a similar squeak on my passenger side rear door. I tried spraying some silicone spray into the hole that the bar comes out of but no luck. I think its something internal, you might have to take the door panels apart. Which seems fairly easy looking at some DIY instructions.
Old Aug 22, 2011 | 01:09 PM
curls's Avatar
Someone stole "My Garage"
Mine have been doing this for years. I've tried silicone sprays (usually awesome on squeaks/creaks), also tried a petroleum-based anti-rust spray which is like a goopy foam stuff that is excellent for lubricating and also creeping into tight spaces. Neither worked.
Old Aug 22, 2011 | 08:28 PM
tsxnub's Avatar
9th Gear
Here is the fix for that. Replace that metal bar( called checker) will fix your problem. It costs like $27 at delrayacura. Go to rear door section and part # is 17/20. Hope this helps.
Old Aug 23, 2011 | 11:07 AM
TYPExR's Avatar
6th Gear
I also had this problem for years and just like curls, I tried almost everything. Then I found Shin-Etsu Grease (http://www.handa-accessories.com/tsx04.html) and gave that a try. It didn't work at first, but I kept swinging the door open and close until the noise lessen. I applied more of the grease and kept on working the doors and magically the noise disappeared.
BIGxRED
Oct 19, 2015 10:47 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
chiu0nthls
3G MDX (2014-2020)
Sep 28, 2015 03:46 AM
dirleton
Sep 25, 2015 12:25 AM
