04 TSX Plastic Undercarriage Cover Replacement
Does anyone have details on how to remove and replace the plastic undercarriage cover on a 04 TSX?
Mines is sagging from all the years of constant heat. I'm scared it's going to fall one day
It's called a Lower Engine Cover.
It is held in place with plastic push-pins and some small bolts.
The push pins can be removed with a flat screw driver.
Usually the bolt heads are 10mm.
I recommend replacing the push-pins once they are over 8 years old, which they are.
See parts: https://www.acurapartsforless.com/v-...-front-fenders
Cover is item 5
Cover is item 5
