04 TSX ABS, VSC, Hazard/Traction Control lights all on
Old May 24, 2012 | 04:10 PM
gmagill10's Avatar
So today I saw that my VSC, ABS and the Hazard/Traction-control check lights all came on. I had just driven my car this morning and the lights weren't on. The lights are constant and have stayed on the last couple of times I've used the car. I have had a pulsing in my brakes for a couple of months now. I took the car to the mechanic down at school and they said that my brakes were all fine.
I did a quick google search for this issue and saw some thread on a Toyota website that dealt with the same issues and they said it was the ABS actuator and it was $2000+ repair. Has anybody ever had this happen to their car and if so what was the issue? I have an 04 TSX 5AT with 116,600 miles. I just want to prepare myself for when I take it to the mechanic. Thanks for the help
Old May 26, 2012 | 10:59 AM
TexasHonda's Avatar
The ABS system has built-in diagnostics. You need to access the stored codes. It may require a Honda Diagnostic System to access the codes. It could be something simple; dirty wheel sensor or failed sensor, etc. There are many possibilities.
If modulator were indeed bad, you can find used units for reasonable prices using car-part.com and ebay as sources. I checked car-part.com and TSX are available for <$100. It's easier to find a local part near your zip code and go by to inspect before purchase.
good luck
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
cycdaniel
Dec 17, 2019 10:58 AM
PortlandRL
Sep 14, 2015 12:01 PM
HeloDown
Sep 8, 2015 06:51 PM
