06 TSX P0962 Cose
06 TSX P0962 Cose
2006 TSX dashboard lit up like a Christmas tree and car went to limp mode stuck in 2nd gear. Scanner got P0700 and P0962, with P0962 as the main one for the solenoid A circuit low. No sign of damaged wiring at connector. Pulled it off, tested ohms perfect @ 6 ohms (manual states normal = 3-10 ohms) put 12V to it and activated normal. Repair manual says nothing about testing connector for proper voltage. What is next steps? Of course manual says use HDS. Thanks!
