[Video] How to replace the door lock actuator on a 2005 Acura TSX
Old 02-21-2012, 01:14 PM
6th Gear
HandsOnThis's Avatar
My buddy and I put this How To video together over the weekend showing how to change the driver's side door lock actuator on a 2005 Acura TSX. Hope it helps some other folks out!
Note - this video also shows why you should NOT use an impact driver to remove those pesky screws from the end of the door.
How to change the door lock actuator on a 2005 Acura TSX
The full blog post is available at HandsOn Blog.
Questions or comments are welcome.
If you have any other how-to videos that need to be done, let me know and I'll see what we can do!
Thanks,
Dan
Old 02-22-2012, 09:15 AM
6th Gear
Thanks,
Dan
Since the links aren't clear in original post...
Video - How to change the door lock actuator on a 2005 Acura TSX
Blog Post - HandsOn Blog.
Old 02-22-2012, 02:10 PM
7th Gear
kdawg123's Avatar
I heard the door actuators for the first gen tsx are prone to failing. are any of you guys experiencing that?
Old 02-22-2012, 07:48 PM
oligoodday's Avatar
my pass. door went out 2 years ago & my driver door last summer... not to bad to replace. runs about 30 @ the dealer...
Old 02-24-2012, 03:09 PM
DannysTSX's Avatar
been looking to solve this problem for ever, thanks. do you guys know where i can find another remote for my alarm, they only gave me one from the dealer i bought my car from?
Old 02-25-2012, 07:45 AM
6th Gear
Yea, you can get a new remote and program it yourself. Here's a link to one on Amazon.
Here's another thread with directions: https://acurazine.com/forums/3g-tl-2004-2008-93/keyfob-question-563383/
Old 02-25-2012, 07:56 AM
6th Gear
I'm guessing that $30 is just for the actuator itself. I got the actuator used in the video for $17.85 on Amazon.
Old 02-25-2012, 01:42 PM
oligoodday's Avatar
saw a bunch online... but wanted to get it fixed right away, so i went to the dealer... thanks for the info...
Old 08-23-2013, 02:53 PM
TSX 2005 Manual
kanonen's Avatar
Just as I finished working on replacing the actuator I found that I forgot a screw . It is the one that attaches the actuator itself to the other white plastic housing.
Anyone knows how tight is that housing, I know it has 2 clips in it (and the screw), but I am not ready to disassemble the door, clips, metal rods and the rest again...
Do you guys think that screw is critical?
Old 08-26-2014, 03:53 PM
zach10's Avatar
does anyone know of a DIY for 2nd gen tsx??
dealer is charging 400 bucks for it
thanks
tman570
06-11-2019 07:56 AM
handsom-hustla
11-13-2015 05:04 PM
redman333
10-09-2015 10:12 AM
brjones9
09-03-2015 07:30 PM
nuldabz
09-03-2015 05:49 PM
Quick Reply: [Video] How to replace the door lock actuator on a 2005 Acura TSX
