MY TSX dropped on Eibach Sportlines
VTECSTASY!
Hey guys... I've had a couple people ask me for pics of the Sportline Kit so here they are. Sorry for the crappy pics... im picking up a digicam this weekend so ill post better ones.
VTECSTASY!
no... just springs. They are a step more aggressive than the Eibach pro-kit which alot of members have. The ride is a little bumpy but it LOOKS great.
wow, looks a lot better without that darn wheel gap...
did you get a camber kit as well? but i'm thinking about getting the comptech springs because the retailer i talked to claimed that the camber kit was not needed since the drop was only 1"
VTECSTASY!
Originally posted by domn
How much of a drop front/rear is that?
VTECSTASY!
Comptech is nice... i would go for the springs as well but the drop is not aggresive enough for me. You should also look into the MUGEN springs available. They also lower the car 1 inch but its already pretuned by MUGEN (damper settings). All for $1,000.00. www. kingmotorsports.com
VTECSTASY!
Originally posted by ortiz
How much were your springs? Did how much was the install or did you do it yourself?
VTECSTASY!
Originally posted by BDI
how is the ride on the springs??
Originally posted by onenonlieTSX
Springs were $260 from a local shop and I installed them myself. (i dont recommend this unless you have past experience installing springs).
the sportlines are even cheaper than the pro kit
VTECSTASY!
I think you should do your research on suspension components and how they work... then decide what you want to do. There is no way you can lower a car using stock springs unless you cut them. Not the smartest idea. My suggestion for a mild drop would be the Eibach PRO-KIT or the Comptech springs. Here are the links to the sites:
http://www.eibach.com
http://www.comptechusa.com
No i have not installed a camber kit yet. When I brought it into the dealer for an alignment they corrected the front negative camber but the rear is still in the red. My camber is pretty bad though... very noticable, especially driving behind my car.
Btw, thanks for the pics. I also bought the Eibach sportline but they are not installed yet pending on the availability of aftermarket shocks.
Originally posted by owenaldo
If I want to lower it only 1.3 front and 1 inch rear, u think I can do it with original spring w/o any alteration? if not, any suggestions?
EDIT: check them out here http://www.acura-tsx.com/forums/show...&threadid=3904
thx for the info on springs........how much are the eibach pro-kit or comptech? or the neuspeed?
I think I can get someone I know who owns a garage to install them for me.....
VTECSTASY!
Originally posted by JTso
I'm curious how did your shop correct the front camber as there's no camber adjustment on the TSX?
The dealer said the front camber is adjustable. Just like the RSX. But the rear needs a camber kit.
They might have adjusted the toe to compensate for camber wear. On the other hand, if the dealer has a method to adjust camber angle without a camber kit, I would like to learn about it.
VTECSTASY!
OMG! Is that what the dealer told you? Did they give you a before and after alignment spec sheet? Because the TSX and the RSX definitely don't have the same suspension design. The TSX has 4-wheel independent double-wishbone/multi-link rear, and the RSX has control-link macpherson strut front/double-wishbone rear. I'm not sure about the RSX, but the TSX most definitely doesn't have camber adjustment. The only adjustment is toe. I just verified that with the factory service manual.
GWEEDOspeedo
01-15-2016 10:39 PM
us285126
10-02-2015 02:03 PM
Eggs999bacon
09-24-2015 10:08 AM
4drviper
09-23-2015 07:42 PM
08, acura, camber, drop, eibach, installing, kit, photo, pics, pictures, review, sportline, sportlines, sportsline, tsx
