LED License plate bulb
I got bored so I decided to go to CDN tire and got LEDs for my license plate.
They are not as bright as the stock bulbs but they give off a crisp white light.
Originally Posted by Jeff The Pianist
was it hard to install? I wanted to change mine...but never bother to figure out how to get to it.
I removed 4 plastic fasteners/screws inside the trunk to partially remove the carpet. Then you grab the plastic piece that holds the bulb by the sides and squeeze and remove. It's really easy.
1 Post
so for these, was it easy to find a replacement? did they have one of their little books that shows u the part number or how did u do that.. .i'm def interested in changing mine too... i haven't made a CT trip in a while, maybe i'll bust out the big wad of CT money i have lying around to get these bad boys for free...
I was curious about these also. I heard that Infiniti makes these standard on new models if i am not mistaken, but im not sure. Do you like the new LEDS? I saw where to get them off ebay and wondered if it is worth the troule.
tec_toyz also has them. you can find them on ebay...just put that under the seller or put LED license plate for TSX. i have them on my car....i like them. makes the car have a luxrious look on the back instead of cheap "amber". he's also a nice guy if you contact him and say that you saw the posts from here...he would cut you a deal if you wanted LED's inside your car as well (i.e. dome lights, door lights)
i bought about 4 sets from him so he's legit (1 tsx set, 2 accords sets, 1 cbr600rr light)
2 9LED Front Door Lights = $10.00
2 4LED Front Map Lights = $8.00
1 4LED Dome Light = $4.00
2 9LED License Plate Lights = $10.00
Shipping = $3.00
Total = $35.00
this is what he gave me
that seems like a good deal. once you get them, and see how easy it is to install and see the end product. it'll be worth 35. people always stop me and ask about the plate lights since they are so bright on a silver tsx (i got white led's). makes ppl think u have an is250 or is350 since they come stock with white plate lights.
i am not exactly sure the specific #'s he gave me...cuz i bought 3 sets of led's for interior and exterior at one time.
the "discount" i meant, sorry...should have been clearer, was that you can pay him straight through paypal and not through ebay THEN paypal. that way he gets all funds and no ebay fees so he cuts off a little cash from the bill. that what i did with him and he paid for shipping as well. but i have bought a lot from him though...so mighta been a repeat customer discount.
mmmmmm....
I'll try to take a better picture tonight and post it.
Did he give you a good deal? I am about to buy mine..i didn't know he give discounts...
Shipping = $3.00
Total = $35.00
Shipping = $3.00
Total = $35.00
I did not know you guys like the LEDs. Actually, the following areas can be done
1. All doors, usually single LED but there is now 2 or 4 LEDs.
2. License plates and sometimes at night, the white light may not throw enough and hard to spot the plates.
3. The map reading light as well as the interior centre light. Usually a 6 LED for the centre interior but some residue current tends to keep it alight. Likely it is the capacitor that cuases the delay of lights going out after door is close.
If I knew, I would have bought more of these as easily can mail them to you guys. It will be cheaper than what i see above...
I had some of the blue 9LED's above my license plate and they broke twice. tec-toyz sent me replacements, but they broke again. so I switched back to stock. has anyone else had this trouble? I think it's from excessive rattling.
Originally Posted by MTLer
How much was it from cdn tire?
You have the model # or pic of packaging?
They're made by Euro-lite and I believe they were $11.99 for a pair. The model is 194.
Pimpin' Euro
i use to have LED number plate lights. PIAA bulbs that can also be used on the parkers
after about 3-6 months the one of the bulb flickered and died. i have since replaced them with just BI Hybrid POLARG white parker lights. i dunno if its the LED or the car, ive been thru 3 packs of PIAA and 1 pack of RAYBRIG led whites now and they all seem to flicker and die after a while. the longevity is no where near as long as just normal bulbs
just a word of caution.
but yeah i agree it looks niiiiice at night.
Originally Posted by TSX7
Ya I'm aware of some LEDs failing prematurely. I don't open/close my trunk often so we'll see how long these things last.
The problems with LED is that they cannot be powered up for long periods. Newer ones have built in capacitors. It is only good for short time light up. License plates to side lights on headlights, will not last long.....
Originally Posted by iNteGraz92
wrong
Well, it would have been helpful if you explained. LEDs are sensitive to current surges and when powered up too long, without resistor, they tend to blow.
In hot climate here, we experience this . Let's hear your explaination.
All, this thread describes everything you'll need to know about replacing LEDS: https://acurazine.com/forums/showthread.php?t=7556
Also, I replaced my license plate bulbs with LEDs. My first set did go bad and I think it was vibration as well. I just put in a new set of LEDs from superbrightleds.com and the design is SOOO much better than that first design, so I'm hopeful.
Everything in my car, minus the turn signals and vanity miror lights are LEDs.
The glove box light is stupid to replace because it is useless anyway.
aaar, we talking about different LED bulbs. The small ones that fit inside the doors, could be used for the CL1 side lights. They are build differently...
What am I missing here? Yes, the 194/168 bulbs have a lot of applications in the side markers, license plate, rear markers, and 1 of the rear brake lights (non-2 stage).
EDIT***
What am I missing here? Yes, the 194/168 bulbs have a lot of applications. For instance in the side markers, license plate, rear markers, and 1 of the pair of rear brake lights (non-2 stage).[/QUOTE]
I only want to replace licence plate and all interior lights to white LEDs.
are the LEDs from superbrightleds.com better than tec_toys?
I haven't seen the ones from tec_toys, but I've been pretty happy with superbrightleds.com's stuff and have had them for about 2 years or more. I don't even remember what the OEM lights used to look like to be honest.
Originally Posted by hawaiiantsx
not sure what superbrightlights. com LEDs look like, but i got the ones from tec toys.......if you got the 9 LED ones, they dont fit very well.I had contacted him and he sent me a 6 LED bulb instead which fit much better....if you got the 9 LED, might wanna get in touch with him and ask him for the 6 LED bulb instead.....
I would also recommend superbrightleds.com for replacement bulbs. I have replaced all of my interior bulbs, and rear dash brake bulb with LED's. No trouble yet and fast shipping.
i like mine (got from tec_toyz)...i didn't want them too bright...just not the ugly stock color. plus who wants them too bright so that ppl can see your plate #'s from a mile away?
Did you do the larger style festoon for the interior domes? I've been contemplating those, eventhough my current LED domes are working fine.
Also looking for a comparison of tec_toyz and superbrightleds.com products.
