engine bay cleaned... before and after pics
Originally Posted by BERTSX
that looks good did you have to cover up anything when you hosed it down. Also was the engine hot, warm or cold?
i drove the car around the block for about 5 mins... just so the engine was warm to the touch... but not burning...
Originally Posted by say what?
I put a plastic bag around the alternator...
Btw, did you use water as well?
Originally Posted by JTso
You might consider cleaning it when it's cold. Hope you didn't warp the cylinder head...
How can you warp the cylinder head????????
Just clean with cloth and water should be fine.
^^ you should be fine. i seriously doubt you'd warp the head for just 5 minutes. i see the acura techs do it all the time in the shop, and they charge you $$$ just to hose down your engine, lol.
how would i know if the cylinder head was warped??
Originally Posted by rdc
what is the proper way of cleaning the engine? what chemicals do i need? what are the things i need to cover? thanks
https://acurazine.com/forums/showthr...ghlight=engine
Originally Posted by dwest1023
I use spay and wash. Cleans all the grease and grim and is very gentle. Just spray on and hose off. Been using it for years, and have found nothing better.
spray and wash? the clothing stain remover? interesting.
luther
luther
luther
Give it a try and you will agree. Just make sure it is spray and wash. The other similar products are not as good.
Iakonafuji
09-21-2015 02:39 PM
