DIY lower chrome grill painted
CL9 ABP
So i bought paint from express paint.com
Then got a few boxes
200 grit scuff off chrome and if i messed up
600 grit for primer
1000 grit for clearcoat
Newspaper
Primer (sandable)
and clearcoat
Basically take off the top rad cover and pull out the grill.
Out grill is only held on by buttons and clips.
So then you flip the grill theres a few screws to take off the chrome piece.
Then start sanding it down with the rough grit sand paper.
once its dull you need to set up a box with some news paper so you don't make a mess.
(30 mins - an hour dry time for each layer so when you touch it your finger prints won't be there....)
Primer it about 3 coats is good then sand it down lightly with the 600 grit.
You don't need as many coats but I figure I got nothing to lose.
Make sure when spraying it doesn't bleed too much or run cuz if it dries you might have to start all over.
Then I painted the grill in light spray basically keep a distance so it doesn't push or bleed.
3 coats and sometimes sand out the bubbles and in between.
Clear coat about one or 2 layers then use the sand paper even it out (1000grit)
I messed up the left side the paint bleed and the clear coat got stuck to the newspaper...
So i'm redoing it tonight
Right side came out pretty nice =)!
Cost about 45 bucks everything.
I just need get new sand paper to redo the left side.
600 grit for primer
Newspaper
Primer (sandable)
and clearcoat
I think is going to look nice, especially with your color. I'd probably let it dry for 2 to 4 days before putting it back on as it makes a big difference in the hardness of the paint. I'm looking forward to seeing the end result.
Looks good mang. Pics when its on the car when you're all set.
Might have to do this to my CGP.
I've done a lot of rattle canning on motorcycle parts. A lot of it plastic. Letting the paint cure for a couple days makes a huge difference in it's durability. For smaller metal parts I'll even throw them in the oven for a few hours on 160 or so. They come out with durability close to powder coating. Obviously not an option for plastic though.
CL9 ABP
Yea I mean this isn't ad when your bored at college, and not too much in parts.
Paint 20 bucks about i used it on some other stuff.
Primed and clearcoat 8 each
sand paper 6 each.
sand paper 6 each.
Are you doing the upper chrome part too? The lines of the hood really stand out without the chrome bit breaking it all up. I think it would sort of cheap though without the lip kit. I'll just stick with the chrome.
oh man you like read my mind i was just thinking about painting my grill in some way, thanks for the great write up. Out of curiosity does anyone know if they have CGP Spray paint, or a color thats close to that, any help will be appreciated.
anyone know any auto stores that you can find locally that have automotive paint .
boost owns
This is a great look. I had my upper and lower grille chrome trim pieces painted by a bodyshop last May when I was having some other work done. So much cleaner than stock. My only issue with it is that I've already got a small rock chip in the paint on the upper trim. Hopefully it holds out like that for a while and doesn't get worse. If it does I'm just going to go Mugen grille because I don't want to re-paint the stock.
Crazyazn, where'd you get your paint?
CL9 ABP
Expresspaint.com
Its pretty good match and price it was like 20 for a can. My friend and I was able paint his wrx side skirts 4 coats each.
I repainted my left side it came out better althought i wish i had a dremel to sand it down.
I really like the blue you have and props for the write out. The difference on the red car stand out more though. Good job.
ideal it would look like this but in abp
CL9 ABP
Well you just need to find the paint and do it, we already know alot people tried the blacked out tape and i'm not a fan of tape and sticky adhesive. So i painted mine..
I might end up doing the black trim soon.
CL9 ABP
Just really take your time with the coats and sand inbetween helps everything stick...
I messed up on the clearcoat after
3layers of primer 3layers of paint and 2 layers of clearcoat.
It touched the newspaper on the box i used and ripped chunks off.
So i had to wait about an hour sand down as much as i could then redo those steps on the left side.
CL9 ABP
I had the oem hood trim painted already since i used to have a cf grill.
It was cheap and a temporary look. It didn't last when i got into my accident. So i just got all the oem parts back and salvaged the hood trim.
Its not hard to paint the hood trim.
Just becarefule REMOVING... first time i did it i broke the plastic clips.
TLDude876
12-28-2016 03:18 PM
09-17-2015 09:01 PM
