Type-S/R Limited Slip Differential in TSX
Is it possible to install a Civic si or Type-s LSD on a stock TSX transmission?
Or does it need a RSX tranny for it??
Direct bolt-on, I'm 90% positive. That's what everyone at honda-tech says. The K-series 6-speed transmissions are virtually the same aside from gearing.
Well Im 100% positive I have a civic Si LSD in a 05 TSX. The gearing are interchangble between the RSX / Civic but the ratios are different slightly. The major difference is the tranny housing. The RSX and Civic have the same tranny housing and both will bolt up to a K24 but TSX has different mounting points.
Originally Posted by DAYTA
Do you notice significant acceleration/cornering improvements? Also, how much did the entire setup cost you?
Originally Posted by Redfish
Should be ~$750 online: Honda LSD
Quaife, $900: http://www.manufacturersdepot.com/Pr...054-1180622061
Thats a really good deal! Great find! The dealer price even at cost is 850.00. Im sure these guys can use that route.
Poser / Fanboi
Yes it feels more in tune to the road traction wise. The torque is evenly distributed to the ground. My cost is much lower than it would be for you because my mechanic is a Honda tech with mad connections. But the LSD is about $1100 and the labor for install is about the same.
If you don't mind, could you further comment on the LSD off the track - is there any problem with it interacting w/VSA in limited traction conditions, and is there a different feel to the car under spirited (but still legal) street driving conditions? Have you ever driven on snow/ice with the LSD?
Thanks!
It is a direct replacement for your current manual trans diff.
Poser / Fanboi
Originally Posted by Simba91102
How can it be a direct replacement if the TSX has different mounting point (see post above)?
Originally Posted by hunterk1
The differential with the LSD is a direct swap for the non-LSD differential. It's not dependent on how the transmission itself mounts to the engine. The differential itself is just the final piece of the drivetrain contained within the transmission of a FWD vehicle.
Thank you for answering that.
IIRC, you've posted elsewhere regarding drag racing and that you've achieved some very good 1/4 mile times. It clearly doesn't make sense to run in such events using a "lossy" traction control system (i.e. VSA), so I assume you disable VSA and rely on the LSD to even out torque delivery in the wheels. I expect here it does quite well.
Thanks!
Thanks!
The VSA should not conflict with an LSD at all. The VSA is only looking and reacting to difference in wheel speed in relation to the input from the yaw sensors (I'm only talking about the traction control part of VSA here, the part that cuts your power when the wheels slip). Since the LSD is already helping to prevent the wheel with less traction from spinning, the VSA should have to intervene less.
An LSD will only assist the VSA, not hinder it any way.
Poser / Fanboi
I ran a 14.9 last season with out the LSD spinning in 1st and 2nd gear. I never use VSA I turn it off as soon as I get into the car. [...]
My main reason to get an LSD is completely different from yours - I do live in snow and ice, and occasionally have to ascend an icy hill. With VSA sometimes I just have to give up, because a lossy system just doesn't work well in these situations. Turning VSA off is a little better but then of course you get single wheelspin.
Did you swap to the RSX 2nd-5th gear, as some others have done (Black_6spd springs to mind) or was it something else? The RSX gear swap looks like a nice mod. Good luck with the next season.
Finally - the LSD won't worth with the 5AT? This comes as a surprise to me, do the transmissions have different differentials? I know the AT has a lower final drive but figured the ring gears were interchangeable on the same diff.
Originally Posted by Reach
hunterk1, Black6sp blew out his 2nd gear, remember that. Either have the gears treated or stick with your 2nd if you go for new gearing.
Thanks for replying - in hindsight it makes sense to me that the best quarters are run when you're right at the edge of traction - you have an LSD just in case, but if you actually "use it" (i.e. lose traction) you'll ultimately have a slightly greater time? Is that right?
That makes sense, thanks.
A LSD will help in any situation where more traction is needed whether on dry, wet, dirt or snow. Its very helpful at the track because you are able to put more power/tq. to the ground off the line / in corners.
You are very good! I swapped 2nd/3rd if you look up the RSX/Civic SI vs. TSX gear ratios the TSX / RSX have the same 1st gear and 4th thru 6th are almost the same. The major difference is 2nd / 3rd gears. The TSX has a problem maintaining acceleration/momentum from 1st to 2nd beacuse the gears are not close enough from 1st to 2nd. The older RSX's have I think a 4.3 final drive and the TSX/ 05+ RSX's/ SI's have 4.7 final drive. So if you change 2nd / 3rd gears the acceleration is much more consistant.
I need to do more research on 5AT tranny because I was told that the manual LSD wouldnt work in that 5AT. I might be wrong.
^^ No. Even if you got a TSX manual transmission, there's a lot more work involved than just swapping it out. If I understand correctly there is no other tranny that will even bolt on. These guys are talking about swapping the internals of the transmission into the TSX transmission case.
Originally Posted by castillo183
So its possible to convert over from Automatic to a Mannual using a Civic Si Tranny or RSX- Type S tranny?
SidhuSaaB
05-30-2020 12:40 AM
GWEEDOspeedo
01-15-2016 10:39 PM
