Tsx536's - Auto 5AT - w/ Comptech Supercharger - Dyno / Pics (No 56K)
#122
Torque Steer?
Kenny,
I don't know if this has already been asked. With all the additional horsepower and torque, do you feel any torque steer under hard acceleraton?
#123
Also, (I think there's another thread on it... maybe),
are there any other negative effects on your car as a whole?
Maybe long-term durability or faster wear?
#124
Rep'n Taxbrain.com
First off, let me say sorry for the super long post. It's a slow day at work
Torque steer hasn't been a problem. I haven't noticed any but I'll try to keep on testing this out. I think the amount of power that was added is right along the lines of what can be added to a FWD without ruining the driveability. I will try to do more hard acceleration just to test this out for you Jlukja
I'm very happy with the Supercharger. In the last few days I have been driving more normally and not necessarily trying to push the car hard every chance that I have gotten. The car just drives really smooth and I feel like I have plenty of power on tap whenever I need. The acceleration is a lot more effortless and smooth. Whenever I want to pick up some speed, I don't need to push the engine as hard as I use to. I have a lot of good power in the midrange and don't have to rev the engine as high to get moving anymore. This has helped out a lot around town and on the freeway.
As far as negatives, the only one I can think of is that it is far too easy to go fast now. When I'm going 80 mph on the freeway, I'm only on the throttle about 5%-10% and it feels like the engine is barely doing any work. If I push it to about 50% throttle, I hit 100-100 mph with very little effort. This is a bad thing because I've noticed that I am passing people at 100 mph more frequently now. I always pass safely and make sure there are not cars in the way, but I would still get a huge ticket if a cop were to see me.
I've also been doing some testing with the difference in gas mileage. As of right now, it seems that there is very little difference in my mpg if I drive normally. If I'm at WOT and up in the high RPMs a lot, it definitely uses more gas though. I will let you guys know my results after I've had time to do more comparisions.
I'm not sure about the long term effects, but I've heard that a Supercharged Car can still be very reliable if you don't abuse the engine, make sure to change the engine oil reguarly, and change the oil on the SC blower every 50,000 miles. Other than that there is not really any additional maintenance. Keep in mind that I am running a 5 psi boost which is considered modest.
Also keep in mind that I am only boosting a small percentage of the time. I took the following info from the CTSC FAQ on ClubRSX. Those guys have been running the CTSC on their cars for awhile now and have a kit that is similar to the TSX kit.
Will there be additional stress on my car?
Any performance mod adds stress. However, the CTSC system has a bypass valve that cuts out the compressor when no boost is required, which means that 95-98% of the time you're not boosting and not adding stress to the engine. The compressor uses less than 1/3 of 1 hp when cruising at 60 mph.
How does this bypass valve work?
It is a butterfly valve like the one in the throttle body (see picture). The default is closed. When vacuum is high (idle-cruising) an actuator opens the bypass valve so that intake air bypasses the compressor. When accelerating, vacuum decreases and the bypass valve instantly closes. Intake air now goes through the compressor, building boost.
For the full FAQ, go here:
http://forums.clubrsx.com/showthread.php?t=262546
#129
Hi Bro,
I am kind of interested in this supercharger, but I am not local. I live in Singapore currently driving a CL7 2.0 Auto with a little mod by putting a unichip 32bit and a Apex RSM limited edition. My horespower on wheel now is only 139 before that is only 129. If I am not wrong, supercharger is not available in my country so not too sure how to go about it or what what things I need to do before installing supercharger? Hope to hear from you real soon.
Cheers
Aloylee
Cheers
Aloylee
Originally Posted by Tsx536
I got some PMs from people asking for availability of the Supercharger for the auto tranmission. Well, I just heard back from Comptech and the Supercharger for the Auto is now being sold.
For the auto version, you need to give Comptech a call to get on the list. They will begin shipping the Supercharger for both the automatic and manual towards the the middle/end of next week.
ECU: As part of the Supercharger package, you will need to send your ECU directly to Hondata to get the new reflash for the Supercharger.
#130
Drives With Hands
Originally Posted by cArKc
will it keep up with the TL's, rsx-s, G35's, and even the WRX??
#132
Master Graphic Artist
Originally Posted by sho-one
I only lost 2 mpg my last refuel, and thats with me hitting 140mph and going WOT a couple of times, so the mpg is negligible if not nil. Here are some vids of the 6mt
https://acurazine.com/forums/showthr...t=27968&page=6
I'd love to know how easy it would be to swap the pulley and up the boost.
#133
The Comptech website has been updated. The Auto is now being sold also on the website. I know that you were having some trouble. Hopefully this helps, JMatthew34.
http://www.comptechusa.com/store/product443.html
http://www.comptechusa.com/store/product448.html
#135
Photography Nerd
Originally Posted by acuratsxms
do you think its possible to race a stock G35 automatic with a SUpercharged TSX auto with some extras like headers Etc? AND have a good race
#137
Rep'n Taxbrain.com
Originally Posted by aloylee
Hi Bro,
Cheers
Aloylee
Cheers
Aloylee
#138
Rep'n Taxbrain.com
#139
Rep'n Taxbrain.com
Originally Posted by PixelHarmony
So the vtec being dropped to 3k doesn't affect the fuel consumption that much?
It wouldn't be too hard to swap the pulley. It would take about 1 hour for someone who is experienced. This would up the boost, but without a new reflash you're car will not be tuned to properly and safely make use of the extra boost. You would also need new fuel injectors that will deliver more fuel to the engine. Comptech will most likely release a Stage 2 SC kit at some point which will include a different pulley (smaller for more boost), high flow injectors, and a ECU reflash with new turning.
#140
Drives With Hands
Do we know what duty cycle the stock injectors are at during WOT right now? Normally I think they're already around 70%.
Also, this is becoming an appealing option to me considering that, as an AT owner, I may not be able to use a Kpro when it becomes available for the 6MT models.
#141
Rep'n Taxbrain.com
I think the SC is a great mod. If you ended up getting it and then K-Pro is released, I think Hondata would give you a reduced price since your already an owner of the reflash. I believe that in the past Hondata has given a discounted rate to people going from one of their reflashes to K-Pro.
Take a look at this link for the RSX. They charge RSX reflash owners $500 to upgrade to K-Pro instead of charging the full $995.
http://www.hondata.com/kpro.html
#142
Drives With Hands
Huh, cool. I'll probably figure out what I want to do in a month or two. My shop said they'd be able to put together a turbo system for like $2500 or so, but I've always preferred supercharging with autos, especially now that DBW makes it that much more difficult to modulate boost.
It's only money.
It's only money.
#143
Rep'n Taxbrain.com
Videos!
Here are a couple of short video clips. Keep in mind that I have an 5AT. With an auto I have one less gear than a 6MT. I stay in each gear longer so my tach doesn't move as fast as a 6MT's does. I reach a higher top speed in each gear than a 6MT does though.
Here's a quick comparison of the longer gearing:
At the top of 1st I'm at 45 mph, a 6MT is at about 30-35 mph
At the top of 2nd I'm at 75 mph, a 6MT is at about 55-60 mph
At the top of 3rd I'm at 105 mph a 6MT is at about 80-85 mph
In these videos I'm only pushing it hard in 1st and 2nd gear. By the time I hit 3rd I'm going pretty fast, so I let up on the throttle. These videos were done on some country backroads to make sure no other cars would be around. The sound level is kind of low, so you should turn your sound up. My car is pretty quiet though.
My mods are Comptech SC, Icebox, DC Header, OEM cat, OEM Exhaust.
Enjoy!
Day:
http://media.putfile.com/Kennys-Supercharged-TSX---Day
Night:
http://media.putfile.com/Kennys-Supe...ed-TSX---Night
I'm actually holding the steering wheel and camera in one hand and shifting with the other. So that made it a little tough. Hopefully I can get 2nd gear to move even faster with a little practice in finding where the sweet spot on the throttle is. What I've found is going full WOT doesn't necessarily make me accelerate the fastest. Hopefully changing my CAT will help out with that.
Enjoy!
Day:
Night:
#149
Rep'n Taxbrain.com
Originally Posted by JTso
That's some tall gears and your car is so quiet! Are you running stock exhaust?
My ride is pretty quiet actually. Silent but deadly
I'm going to probably put on the Random Tech Cat next.
#150
Rep'n Taxbrain.com
Originally Posted by HONgDA
so what's the top speed you reached filming this video?
Probably like 105-110 mph. And that's in 3rd gear too
#153
tehLEGOman
Received 1,982 Likes
I almost wrecked the first time i tried to film the gauge cluster and hold the steering wheel. So i came up with a camera mount that hangs down from the visor and it worked pretty well.
I just got done comparing your video clip to the one i made. Both cars seem to get up to 100 fairly quick.
Nice job man!
Nice job man!
#156
Engineer
damn that is sooo sick... more temptation...
#157
Rep'n Taxbrain.com
Nice job man!
Nice job man!
Do you have a link to your videos? I'd like to see yours.
#159
Originally Posted by r33p04s
i was just wondering....is anyone else not disturbed by the fact that the AT loses 64hp through drive train loss compared to 43hp for the MT...and stock its about a 10-15hp difference(about 8% increase over the MT already high 20-25% )...no wonder all the magazines repeatedly say that the AT and MT are esentially 2 different cars (with the MT being the "type-s") version
This graph is also bothering me immensely. I feel cheated.
http://www.hondata.com/images/k24a2a...ck-reflash.gif
#160
Originally Posted by observer
I don't know how exactly to read the dyno graphs, but are you guys saying that my 5AT really doesn't have 200hp (and not even close) like Acura advertised?
6MT
http://www.hondata.com/images/dynots...vs-reflash.gif
5AT
