TSX Header Questions
1. What is the stock collector size?
2. Who makes headers for the TSX with a larger collector than stock?
3. Are there any high flow catalytic converters available that will mate a larger collector size with the stock exhaust.
Originally Posted by JTso
The stock cat inlet is 2.25" so I believe the stock A-pipe is just slightly larger. No one that we know of makes a header collector larger than stock. Aftermarket headers are usually designed to bolt up to a stock cat, and aftermarket cats are usually designed to bolt up to stock header and exhaust. If you want something larger, you most likely have to go custom. I have made a custom A-pipe with a 2.5" collector. I'm now in the process of making another A-pipe with a 2.25" collector to match my cat.
I imagine the same holds true for the K series engines. I will start looking around for JDM headers with a 2.5" collector.
divac
08-29-2018 10:13 AM
DiamondJoeQuimby
09-10-2015 11:40 AM
