TSX door speaker adapters
I hope to post a longer version of this in the future with pictures, but for now I'll just give a quick mention of this part to get the information out there as quickly as possible.
I did search, and I haven't seen it mentioned here before. A firm called "American International" makes a speaker adapter for the 2003+ Honda Accord. The part number is HSB-518. This part has clips that will fit snugly in the original door speaker holes in your TSX door.
There is one complication: For my speakers, the holes already in the HSB-518s were a little too close to the center for the holes in the speakers. Instead of using the holes already provided in the HSB-518, I screwed the speakers into the edge of the adapter directly. There was just barely enough room to make this work. The edge of the HSB-518 was bulging from the screw, so if my speaker holes had been just a hair wider, I probably would have split the side of the adapter and this trick wouldn't have worked. Despite not using the provided holes in the adapter, I do think that I got a pretty secure mount.
You will probably get a tighter and more secure fit if you screw directly into the sheet metal with your own spacers, or build your own mounting bracket. However, the HSB-518 path is probably the least effort if your speaker mounting holes aren't too wide.
If you google for them, you can find the HSB-518s for $10/pair online.
Do these (Metra ones) work well as spacers for the Alpines?
I'm going to go with this soon, and if I need these to space I'd just assume order them now.
Originally Posted by nnh768
I'm thinking of getting these because i'm not comfortable drilling holes into the metal. Is this bracket the same for the front and rear doors?
Originally Posted by moda_way
Metra makes a kit too.
Check out Partsexpress.com and search on 82-4300.
$6.90 a pair.
$6.90 a pair.
Originally Posted by jlukja
Ron,
You went with the Alpine SPS-170A ?
The issue now is that I'm noticing that (as I believe you predicted) the tweeters sound a bit harsh compared to the clean sound from the rest of the system. I'm looking into replacing the tweeters with some good silk dome ones, but it doesn't have the urgency of the door speaker replacement since I can now listen to most music without cringing.
BTW, the Dynamat Extreme installation eventually got easier as I mastered working with the material and twisting around to install it. I do feel like it has reduced some sources of noise, but plenty still remain. The engine now sounds a bit louder because there is less competition from other sources. The main annoyance remains rough or concrete roads, which just seem to resonate through the entire body of the car.
Originally Posted by Ron Parr
Yes - I'm quite happy with them. Thanks for all of the tips you gave over the past few weeks while I was working through the issues!
As for tweeters, I've been reading very good things about the Vifa D26NC05-06 and the LPG 25NFA. Take a look at them and them to see what others are saying.
Originally Posted by STL
Is this the place you got them?
Originally Posted by joerockt
Will these only fit the front doors? I wonder if the rears have the same setup...
I've got 2 sets ordered and I'll let you know eventually
But really, I'm a while out from actually doing it, so I won't know for a some time. I've been ordering parts piecemeal for the last month. Maybe another month and I'll have everything.
Now have / ordered:
JL 250/1 amp
ElDude's custom sub box / DLS 10"
Honda speaker hookups and splitter for 6x9s & sub to share signal
Door mounting brackets for all 4 doors
Next paycheck:
replacement door speakers for all 4 doors (prolly the alpines) and tweeters
After that: get someone else to do it all for me
Now have / ordered:
JL 250/1 amp
Next paycheck:
Pictures Added!
Sorry I don't have time to organize these better. Here's the link:
http://bellman.cs.duke.edu/~parr/speakers/
131 & 132: Front then back view of the original speakers
133 & 134: Front then back view of the mounting bracket
135 & 137: Speaker with the bracket temporarily held in place with tape. Notice that the holes for the speaker don't line up with the holes in the bracket
138: Example of a hole drilled in the bracket
142: Speaker screwed into bracket. Note that I didn't use the screws that came with the speakers b/c they are too long. I also angled in slightly when driving the screws.
144: Side view. Notice the edge of the bracket bulging.
148, 149 & 150: Back view. Notice that one of these didn't grab that well, but I think it will still hold.
151: Installed!
151: Installed!
Ron,
How deep is the mounting bracket? (i.e. how far away from the door metal does it hold the speaker?)
Looking at those pictures the OEM speakers really do appear to be crap. I'm thinking I should be able to rip out the stock cone/driver and modify the OEM bracket to be my spacer -- thus avoiding having to purchase any new brackets.
Thanks for the pics. To my eye, the bottom part of the bracket that holds these spacers to the doors looks different in pic 133 compared to what I see in pic 134. Did you maybe get two slightly different brackets?
rockyboy
12-06-2022 02:29 PM
cycdaniel
12-17-2019 10:58 AM
akbears15
15
11-05-2015 07:06 AM
ivegotthenav
09-11-2015 07:51 PM
