There maybe hope for us TSX's
#161
Boost Junky
Originally Posted by godfather2
that torque curve is as flat as i've ever seen!
#162
Pfft!
well still having some trouble at the switch over from vacuum to boost. I got the impression for the company that was doing all the work that they really don't care if they fix it or not. Seems like they just wanted my money. I am going to another shop tomorrow to get their feed back. The tuner at the shop is aem certified so that might help out alittle as well.
I'll keep you posted.
#163
Boost Junky
so the car just basically falls on its face during the transition? What does the wideband read? Is it running really rich? Pull the plugs and check them if you havent already
#165
Former Sponsor
I am really surprised none of you supercharged TSXers are running methanol injection. A number of the supercharged TL guys did it and they saw decent gains. Typically on the Stage 1 kits, which are recommended for low boost applications, you will see a 10% gain. The kits are inexpensive ($250 shipped) and with the Stage 1 you just let it inject and let the ECU throw more timing in based on what it sees. So you don't have to custom tune it or always have it in the car. Of course you can get more hp with a custom tune but the ECU will make adjustments by itself.
#166
Rep'n Taxbrain.com
#167
Rep'n Taxbrain.com
As mention aboved, what is the A/F ratio when this happens?
#168
tehLEGOman
Received 1,982 Likes
...just got done reading all 7 pages of info.
Gotta say nice work bro! It always takes some balls to be the guinea pig when it comes to work like this, especially when over riding an ecu.
Impressive numbers, let me know when you're in Charlotte and we'll meet up.
#169
Pfft!
Well....
I am out in Utah now on Vacation and decided to take my car in to put it back to stock. I told them to try one last thing before going back to stock..
Well I got a message from them yesterday and they told me it is running great and the new stats on it is 276 whp and 215 tq!!!! I will fill in the details when I get back from my trip
and after I test drive it. The best thing is that it will only cost around $300 with parts and labor.
Ben
Ben
#170
B A N N E D
new stats on it is 276 whp and 215 tq!!!! The best thing is that it will only cost around $300 with parts and labor.
Ben
Ben
![Big Eek](https://acurazine.com/forums/images/smilies/bigeek.gif)
#171
Boost Junky
Originally Posted by TSX Wisc Badger
WHAT?????
#175
Pfft!
There is no reason to wait until I get home....
We went back and put the stock injectors in. Took off the AEM FIC and put the ACM back on by itself. We crushed the fuel regulator alittle more (when installing the sc you have to crush the fuel regulator). We kept the 255 fuel pump on (not sure if it is nessesary to have)
Put it on the dyno and hit those numbers..![Smile](https://acurazine.com/forums/images/smilies/smile.gif)
With that being said I will have some RC 650 injectors and a AEM FIC that were used for two weeks.
#176
Ticket Slow Drivers
Yep, he just got one of these - $30 plus installation cost, made 276HP:
Supercharge your car, truck, van, boat, RV, or motorcycle in just a few minutes.
http://www.turbonator.com/index.html...ePowerBaseCars
![Racing](https://acurazine.com/forums/images/smilies/racing.gif)
WHAT?????
#178
Pfft!
Originally Posted by Redfish
Seriously though, Great Job Ben. Looking forward to seeing 1/4 mile times, when the warmer weather comes...
As far as 'crushing the fuel regulator', do you think there is more tuning available with an adjustable FPR?
#179
#180
Pfft!
I will post the new dyno when I get back to atlanta. A/F are around 13. The pulley is a 3.0. The aftermarket fuel pump is still on and not sure if it is needed. I just didn't want them to charge me to take it off. They did more modification to the fuel pump regulator.
#181
Drives With Hands
What is your fuel pressure at now? I'd think that an adjustable FPR would be a good idea now that you're clearly well above stock levels, just to trim it back if desired.
Also, that AFR is a little high for that much boost through a blower...I'd want to keep it in the low 12s at WOT at most, just as a general rule, but if you're not running into knock retard then it might not be a worry for you.
Congrats on those numbers anyway; they're pretty impressive.
#182
Pfft!
#183
Again, this brings into question what a water/methanol injection kit could add. That would adjust your A/F ratio a bit to where you're running a little richer than 13.0, not to mention reducing the IAT noticeably since you're running higher boost (i.e. higher temps).
#184
Boost Junky
#185
Pfft!
Once I see how my a/f is going to run I will let ya'll know. How much richer could it run though with a water/methanol injection kit? From what I have read it would give me close to 300 whp. Front wheel drive ftl.
#187
Boost Junky
It can richen you up into the high 11's low 12's range if enough is being sprayed...Short answer as far as forced induction goes, you generally wanna be running more on the rich side than lean.
#189
Pfft!
We ended up putting stock injectors back in it and crushed the fuel regulator alittle more to allow more fuel to flow. I to have a 255 Walbro fuel pump which I am not sure if that is needed. Everything seems to be running fine. A/F are at 11.7 and I am running 10-11 psi. I am looking into an adjustable fuel regualtor but it would have to be a custom setup since our FR is in the trunk.
#190
Sounds great! Any driving impressions?
Also, just to confirm - the only mods you've done to your S/C are:
1) 3.0" HBP
2) larger fuel pump
3) crushed fuel regulators
If so, those are some amazing gains for not that much more $$$. 215wtq is EXACTLY where I'd like to be...
1) 3.0" HBP
2) larger fuel pump
#191
Pfft!
1) 3.0" HBP
2) larger fuel pump
1) 3.0" HBP
2) larger fuel pump
#193
Rep'n Taxbrain.com
1) 3.0" HBP
2) larger fuel pump
1) 3.0" HBP
2) larger fuel pump
How high are you reving? I think there is extra power up top in the power band, but our injectors run out of fuel up top with the stock setup. Maybe the fuel pump and and crushin the regulators help though.
Do you know what duty your injectors are running close to redline?
So you made no changes to the Comptech ACM?
Way to keep modding man
#195
Pfft!
Originally Posted by Tsx536
Also, Comptech has modified higher flow injectors for sale. I wonder if you could just run those.
#196
Drives With Hands
Anybody know what boost levels these K engines start to float valves at? I figure if you're running better than 10# in the manifold, especially up near the rev limit, the intake valve springs have a much heftier job to do than they do at baro. It might be a good idea to look into stiffer valve springs if you don't want to kiss a piston in the long term.
#197
luvs redheads!
Valve float is cause by high RPM revs..not boost. Therefore unless he has custom cams or feels like revving to 9k all day he shouldnt need upgraded springs.
#198
luvs redheads!
AFter looking at your dyno sheet if they can keep the fuel coming at higher rpms then it is possible if you upgraded your valvesprings to keep going!!! my gosh nice curves!
Also what about upgraded cams to extend the curve farther out..? Good work!
#200
Drives With Hands
