Spoon Calipers
I kAnt Spel guD
Spoon Calipers
Can someone shed some info on these brake upgrades or other BBKs that reuse or fit with a stock sized 17" rim?
Just curious I think CCC has a set and they look really great. I'm thinking of upgrading the stock brakes on our TSX. I'm already using Hawk HPS pads but I think I need something more.
Unauthorized User
Lito also got a set of spoon Calipers on his ride, These will fit over the stock rotors. You will most likely need a new set of wheels bigger than stock 17" because it might not clear.
I kAnt Spel guD
Our OEM calipers clear a 16" Honda rim. So if the Spoon's are a tick bigger they should fit on 17"s but I'd like to hear from somebody with them that has tried.
Also where do you purchase them? I'm assuming you need to contact one of the JDM parts vendors?
where is my garage?!
1 Post
don't the spoon calipers take some different sized pads? i thought this was kind of the drawbacks. you have to shell out more for some specific/custom pad that fits vs. using hawk pads or something.
T.DoT P.I.M.P. lol
1 Post
The calipers can be use on stock rotors, and I wish it clears it can clear my 16" winter rims w/ some spacer.
Originally Posted by CGPTSX06
If you are using the stock wheels you will need some 5mm spacer to clear. Do a search they are everywhere.
hahahaha, MrChad is not a fan of spacers. Guess this will kill of the Spoon caliper mod.
I kAnt Spel guD
I guess now I'll have to call the TireRack and see if any of the Brembo GT BBK kits will fit with the OEM wheels?
I bet the A-Spec rims I have would clear, but I still want to use the OEM rims in the winter with Dunlop winter sport M3's - which are almost brand spanking new from little use last winter.
Else I guess option (B) is to replace the pads with something more aggressive and new rotors. I actually think the Hawk Ceramics I had before the HPS pads put down more bite.
Received 3,860 Likes
no big brake kit will fit the oem wheels I am almost possitive as the tsx stock wheels have to high of a offset of +55. I am running 17x7.5 +40 volk te37 and I would almost be certain that if the wheel was +45 it would hit the brake caliper. I would say most brake kits will require a wheel of at least +45. If you get the right set of spacers that have studs built into them I dont see the problem. check out the 10mm spacers by project kics.
I kAnt Spel guD
Ok group, any help here... Will the Spoon calipers really clear the 5-star rims?
I have measured and I have about 14mm's of clearance between the OEM caliper face and the rear of the A-spec rim 10 spoke design rim.
I kAnt Spel guD
I will measure how many mm are between the caliper and the volk te37 I have on tonight. I think its less than 5mm and personally think you need atleast 3mm to be safe.
Do you know if your Spoon's stick our more or less then your old Rotora's as well?
I just bought a set of Work Meister S1's with a +40 offset, I planned on getting the spoon calibers sometime in the future so I sure hope they clear.
Winter might be tough cus I'm going back to the OEM rims but if a 5mm spacer works I'm sold.
08_UA7_Gr33k
02-11-2016 02:17 PM
08_UA7_Gr33k
09-27-2015 01:56 PM
