sound system question
Old Jul 24, 2005 | 08:23 PM
tsxgoogs's Avatar
i was looking into adding a sub to my stock system and i was wondering if this would void the warranty or would the dealer just hassel me when i return the car after the lease is up
Old Jul 24, 2005 | 09:41 PM
GIBSON6594's Avatar
My Garage
If you serach you can find a ton of info on the warranty and how it is voided
Basically, your warrant cannot be "voided." If the sub you add is the specific reason for an electrical problem that your car has, then and only then is the dealer is not obligated to fix the problem.
Old Jul 24, 2005 | 09:46 PM
Tsx536's Avatar
Rep'n Taxbrain.com
Your warranty will be fine.
Since it's a lease, just make sure to do a clean job on the install. Since you're only going to be adding a sub, then it's not too bad.
Just tap into the rear 6x9's with a LOC and get the signal there for your sound. Tap into the OEM amp or FM antenna amp for the remote turn on wire. Then run power from battery down driver side. Make yourself a ground and you're all done!
Old Jul 24, 2005 | 10:07 PM
elduderino's Avatar
VP Electricity
The A/V forum has a whole DIY list for the TSX : )
mada51589
Jan 9, 2025 04:40 PM
rockyboy
Aug 4, 2024 10:35 AM
Feb 25, 2020 09:57 AM
TLDude876
Dec 28, 2016 03:18 PM
Iain MacLeod
Sep 17, 2015 01:01 PM
