So I hit the dyno yesterday...
I mostly wanted to monitor knocking conditions, but of course I also wanted to see how much the pulley upgrades (high boost + lightweight crank) and the water/meth added.
As a point of comparision, my initial S/C + I/H/C/E dyno was 251whp/190wtq with STD correction, 5 smoothing.
Here are the results. I haven't received the raw data from the shop yet, so this snapshot off a scanned PDF is all I have. When looking at them, refer to the numbers at the bottom of the page. The points on the plot reference engine speeds post-cutoff:
![](http://img384.imageshack.us/img384/8066/dynowhbp09242008largepo5.png)
I hit ~276whp/211wtq with STD correction, 0 smoothing (5 smoothing should drop the numbers 2-3 hp/tq). On my best run, I basically made an additional 25whp/20wtq over the stock S/C setup with the pullies and water/meth, no tuning or other mods. This is about what I was expecting overall.
More importantly, we used a scan tool to monitor ignition advance and from what I saw there was no timing being pulled. From vacuum to boost at 3k, it started at 18 degrees and progressively went up to 22.5-23.5 degrees at redline. Coupled with my consistent dyno pulls (i.e. no erratic power spikes anywhere), it appears the engine is running smoothly. I took it to redline a few times yesterday, and it felt excellent.
What I found rather interesting was that I experienced no heatsoak whatsoever. Running more boost with a Roots blower, I expected power loss to hit after 4-5 runs. Instead, the car actually got STRONGER with each successive pull. My best runs (in terms of torque, anyway) were my last 2 (runs 9 & 10). Even after all of the pulls, the blower was cooler than the ambient temp. I guess the water/meth really does function well as a cooling agent.
One thing I will say, I now understand what people mean when they say 300whp+ in a FWD car is useless. I'm getting some serious torque steer under fast acceleration, to the point where I don't want any more power than I have since my car is being used as a DD. In fact, I'm fairly confident in saying that I'm done with power mods. My following phase(s) will now address other characteristics (most likely traction is next
![Ninja](https://acurazine.com/forums/images/smilies/ninja.gif)
boost owns
Very impressive man. It's good to know there are options out there to hit impressive power numbers in the TSX. Between you and Ben, the pioneering work you've both done is really valuable to the community. You won't be the last TSX to go the route you have (and I say this because I plan to do so in 2009 with my car.)
Looking forward to the next time we take your car for a spin.
Received 3,763 Likes
That is extremely impressive man. This is definitely my next mod. Hopefully the fact I only drive my car less than 5k a year will allow my auto tranny to hold up with the extra power. It would be awesome if you could do a detailed post as to all the equiptment that you have added for this upgrade from the base supercharger. It would really be nice to know what I am in for in terms or price. Hopefully I will be able to tackle the install since I managed to tackle the supercharger install successfully.
boost owns
Appreciate the comments
If you guys are willing to make the trip to CT, I'll provide the ride
Maybe...maybe not
I'm impressed that I was able to hit those numbers with an OEM clutch/flywheel (granted I only have 25k miles on the car).
Thanks man
. If the garage wasn't such a clusterf**k, we already would have gone for a spin.
I'll try to do that in a bit. To be honest, there really aren't that many additional parts needed beyond the S/C to get these numbers, but I would HIGHLY recommend adding boost and wideband A/F gauges to be able to monitor what your engine's doing at any given time. And like Audioserf said, the gauges and water/meth kit might need to be done by a shop. C'mon...Excelerate isnt that far of a drive for you
![Roll Eyes](https://acurazine.com/forums/images/smilies/rolleyes.gif)
Just from having looked at Jason (DAYTA)'s car, I think you'd be able to do the lightweight stock-diamater crank pulley and the HBP yourself, Colts. The methanol kit and the gauges he's running might be a bit trickier (involves drilling bungs into the intake tubing and the header, as well as some wiring I'm not going to begin to pretend to understand).
CL9 Tuner
Great numbers man. How much boost are you getting with the new pulley? Do you have the auto tensioner or manual tensioner? What size belt did ya go with? I'm toying the idea of adding a HB pulley myself but I dunno if I'd do the whole water/meth conversion.
you couldnt do the high boost pulley with out the water meth setup. you can't tool the full maps or anything on the engine and would knock without the addiction of the water meth setup.
As CCC mentioned above, you can't just add the high boost pulley and call it a day. You will have to compensate leaning out the mixture by adding fuel. IMO, running water/meth is the best solution since we currently don't have a viable tuning option and it's difficult to further modify the fuel system. It also functions as a cooling agent which make our Roots blowers more efficient. My A/F ratio is perfect (mid-high 11:1) and the car runs smoothly.
I always have to keep an eye on the water/meth levels or else my engine will blow, but the power gains are worth the hassle and cost to me
Thanks man. I'm just really happy it has worked out well so far. I actually have actually noticed some significant torque steer, especially in 1st and 2nd gear, but it's definitely controllable once you get used to it.
4drviper
09-23-2015 09:00 PM
