Single Side Exhaust
Old Aug 30, 2005 | 07:35 AM
moda_way's Avatar
Single Side Exhaust
I took some shots at Mid-Ohio Grand Am that show it is possible to do a single-side exhaust for some performance. Both Kensai and Stewart teams are using it in their race platform.
https://acurazine.com/forums/showthread.php?t=25098
Old Aug 30, 2005 | 02:30 PM
drkangel348's Avatar
My next planned project is a custom mandrel bent single outlet exhaust with 2.25" piping.
Old Aug 30, 2005 | 03:31 PM
Stein357's Avatar
B-Series For Life.
2.25" is too small IMO...
Old Aug 30, 2005 | 04:01 PM
rmpage's Avatar
Drives With Hands
Single exhaust is the way to go. Duals make no sense on engines without two cylinder banks, and only then when they are completely independent all the way back. If I could figure out how to do it without leaving a big hole where one of the tailpipes comes out, I'd have done it already.
Old Aug 30, 2005 | 04:10 PM
Well I'm debating between 2.25 or 2.5.
Old Aug 30, 2005 | 04:22 PM
ILoveMyHonda's Avatar
17781708
Ins't there someone on this forum that has a European Accord with the single exhaust model......i think it was red......had the rear factory lip with the left sied exhaust opening closed off.......anyways....sweet cars......good pics......One day I will have the 5zigen exhaust
Old Aug 30, 2005 | 04:32 PM
afici0nad0's Avatar
ya, i think it was someone from belguim? can't remember the exact location...
Old Aug 30, 2005 | 09:19 PM
Benz_05_TSX's Avatar
There's actually 3 single exhausts out..... that i know of... Spoon has one, 5 Zigen has one and J's Racing just came out with one!! Great sounding one too!!
BUt, i felt it's weird that the rear has an empty hole, unless Honda Japan has something to close it off.....hahha!
and, what's the difference between single vs. double?? Is it single has more high rpm power and double has more torque at low rpm?
Old Aug 31, 2005 | 12:53 AM
rmpage's Avatar
Drives With Hands
A single exhaust system doesn't use a Y pipe near the rear axle like most TSX catbacks have. There is less turbulence, and the exhaust system can be free-flowing throughout. This is ideal with a four cylinder engine.
Dual exhausts are beneficial on engines with two cylinder banks. For example, with a true dual exhaust on a 350cid V8, two entirely seperate, complete exhaust tracts treat the V8 like a pair of 175cid I4s. It is much easier to pipe it for maximum flow this way, and to match it to the engine's own flow characteristics.
Y pipes, be them splitting or combining, cause backpressure.
Old Aug 31, 2005 | 02:04 PM
HoRRo's Avatar
iVTEC no koe
Spoon has a single exhaust setup?? I thought they only had N1 muffler kit? Do you have a link for the single, sounds rather tempting.
Old Aug 31, 2005 | 03:12 PM
CGTSX2004's Avatar
True, though as I understand it, on the TSX, the dual system is more used to quell sound and reduce the amount of exhaust noise.
Old Sep 1, 2005 | 03:39 PM
xizor's Avatar
Bye TSX, hello domestic?
Single side exhausts can also be slightly lighter, which is also a benefit
Old Sep 6, 2005 | 09:53 PM
TheMirror's Avatar
Disinformation Terminator
Stick with the 2.25 if you're car is normally aspirated. 2.5 probably won't scavenge well enough and you could very well see a performance drop. Too big.
Old Sep 7, 2005 | 12:12 AM
Chris_F's Avatar
yea i remember that red accord in belgium...
i'd go single exhaust if i could get that "hole cover".
i wonder if one of the traders on this forum (like mr. heeltoe) could source the part from honda. That'd be very cool
pstomps
Feb 20, 2017 03:29 AM
Sep 14, 2015 10:09 PM
Sep 14, 2015 10:48 AM
Jpro
Sep 13, 2015 07:14 PM
