Replacing Fog Light Bulbs
Sorry if this has been answered somewhere, but how hard is it too just replace the blbs for the 06 tsx fog lights.. I got bright yellow ones that I wanna put in, is it managable or is a lot of work required..
Thanks in advance
Thanks in advance
There are literally Two Bolts you remove to install the bulbs. One for each side. Once you do, you fold the flap in, or just stick your arm in, easy depending how big your arms are, and you disconnect the wire to the bulb, then you Turn the bulb to the left, then pull out of the slot. Same applies to both sides.
https://acurazine.com/forums/showthr...ighlight=Nokya
Many have put in simple input here.
I've done it twice, once for me, and once for another member on here.
How to replace fog bulbs
Hope that helps.
Hope that helps.
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
