Replacement fog lights
John Starks - The Dunk
I searched and couldn't really find an answer so I am throwing this question out to you guys.....
Basically my fogs cracked while having the Xpel guard on them.....Xpel is reimbursing me for the lights.
I know that it was said that the CR-V fogs are the same, but its still $200 for the replacement ligts. (which i can't find on HandA but someone on the board said they found.)
I really don't want to spend too much on the fogs because I know they will just crack again.(The ones that are being replaced were cracked within 3 weeks) I was wondering if the RSX lights were the same as the TSX because I was on the RSX board trying to search for answers and found out there is a replica non OEM version for their car for $95 a set. Which is only 1/2 the price and wouldn't make me feel bad for cracking them. Anyone know if they will fit, or if i could get cheaper lights to fit the OEM housing?
Also, on HandA.... where can i just find the fog lights, not the fog light kit? Couldn't find it.
Did you try PMing asukal01 and find out where he order it from?
It sounds like he only ordered the "right" foglight kit, but HandA only lists them as a pair. You might want to ask him how you can order only one side, if you only need to replace one fog light assembly.
If PMing doesn't pan out try going to your local Honda Dealer and see how much the 1 fog light part for the CRV will run you.
Here is a Link to his thread where he confirmed the fog light assembly is a match but the mounting hardware is not.
https://acurazine.com/forums/showthr...ht=replacement
EDIT: This should also probably be listed in "Problems and Fixes"
Thanks viking,
already sent him a PM, but nothing yet. He was the first person I tried to contact.
Anyone know if the RSX fogs are the same exact thing as ours? I have two holes from taking the fogs out so I would like to order them soon.
Marmbo
4G TL Problems & Fixes
09-21-2015 09:39 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
