Is it possible to increase the compression ratio of the engine?
Old Oct 14, 2004 | 01:29 PM
ignatiuslee's Avatar
I discovered that the type-r engines usually have a higher compression ratio to give a high hp. So, I wonder whether we can increase the ratio to gain performance.
Old Oct 14, 2004 | 01:32 PM
Dan Martin's Avatar
Photography Nerd
You don't want to increase it unless you're going to use race fuel.
Old Oct 14, 2004 | 01:34 PM
race fuel? that means higher octane?
how come in japan the type-r engines have a high compression ratio?
Old Oct 14, 2004 | 01:37 PM
Dan Martin's Avatar
Photography Nerd
It's already 10.5:1 which is pretty high. You could probably get it up to 11:1 on 93 octane but anything higher would likely cause detonation if you didn't run race fuel.
Realtime runs 12.5:1 on their TSX but they also use 112 octane.
Old Oct 14, 2004 | 01:44 PM
oh ic
thx very much
that means we couldn't use the type-r engines here because of our fuel...
Old Oct 14, 2004 | 02:02 PM
TSX 3Pedal's Avatar
Use all 3 Pedals at once
I want 93 octane fuel...
The hightest that I have seen is 91 octane here in California, as far a I can recall, and that's what I use...
Old Oct 14, 2004 | 02:03 PM
Dan Martin's Avatar
Photography Nerd
Originally Posted by ignatiuslee
oh ic
thx very much
I guess that could possibly be a good reason why it's not offered here. 11:1 seems to be the magical barrier here in NA. The S2000, 360 Modena, and Gallardo are all around 11:1. Even the legendary ITR is only 10.6:1.
Old Oct 14, 2004 | 02:04 PM
Dan Martin's Avatar
Photography Nerd
I use Sunoco 94 on a regular basis up here. :P
Does lower octane make for a cleaner burning fuel?
Old Oct 14, 2004 | 02:07 PM
you are lucky....
Old Oct 14, 2004 | 02:13 PM
DEVO's Avatar
putting higher octane gas in your car does not affect your car's comprasion ratio (just in case anybody read the above threads incorrectly).
another myth... placing higher octane gas in a car that requires regular octane will increase performance.
this is completely FALSE.
lastly... what octane method are they using... 93 octane here (USA) is the same as the high octane gases found in europe.
Not to mention, just about everywhere around where I live you can get 107.
Old Oct 14, 2004 | 02:20 PM
Dan Martin's Avatar
Photography Nerd
While this is all true, I wasn't trying to imply that I would get better performance by using 94 instead of 91. I use Sunoco 94 gas exclusively because it doesn't contain any MMT unlike most of the gas stations up here.
Old Oct 14, 2004 | 03:03 PM
AZTSX's Avatar
Mmt?
Old Oct 14, 2004 | 03:12 PM
Dan Martin's Avatar
Photography Nerd
Originally Posted by AZTSX
Mmt?
http://www.organicconsumers.org/corp/CanadaMMT.cfm
Reader's digest version:
Originally Posted by the article
A few years ago, Honda found that oxygen sensor failures were considerably higher in Canada than in the U.S. The automaker also found that manganese-coated sensors signal the Electronic Control Module (ECM) to enrich the air/fuel mixture, which increases hydrocarbon and carbon mon-oxide emissions.
Old Oct 15, 2004 | 09:29 AM
DEVO's Avatar
Right... i know your situation. MMT sucks.
Old Oct 15, 2004 | 10:58 AM
MC-CL7's Avatar
With bigger cams and good tuning, my old B18C5 engine was at 11.5:1 CR and I was using 91 octane.
Old Oct 15, 2004 | 11:43 AM
LHospital's Avatar
I think Europe uses the RON octane rating (Research Octane Number?) but the US uses the average (RON+MON)/2 (Motor Octane Number?). I maybe wrong.
Old Oct 15, 2004 | 04:03 PM
DEVO's Avatar
you are correct, hence... don't compare octanes between countries.
Old Oct 18, 2004 | 06:44 PM
kurt_bradley's Avatar
You could use a Spoon Head Gasket and not have to use higher octane (without worry of detonation).
Old Oct 18, 2004 | 11:15 PM
BlackTSXer's Avatar
Teh seX
does k20a spoon head gasket fit our tsx...and wats the price?
Feb 25, 2020 09:57 AM
1fatcrxnem1
22
Jun 1, 2018 01:23 AM
Sep 17, 2015 09:01 PM
Sep 15, 2015 06:44 PM
Sep 13, 2015 01:59 PM
