is it possible to change your transmission from a/t to m/t ?
yes it is possible. it requires quite a few parts though. however if you buy all the parts used from junk yards you should be able to do it for around 3500 including install. you need a lot more than just the transmission. you need the transmission, ecu, gauges, clutch pedal, clutch master reservoir, clutch cylinder, engine harness just to name a few. I have been heavily researching this and plan to do it sometime in the next year cause my warranty will be over by then.
Originally Posted by nycxtsx05
you seriously think its not worth it if you can do it for 1200 ??
thats alot better than i was thinking
DrkAngel843 did the swap. I'm not sure if that's his exact user name, but it's close.
Originally Posted by Tsx536
Dom traded his AT in for a MT
I found a shop that said they think they should be able to do it for like $2500 but that I should estimate on $3500 for an unknown costs.
There is a thread somewhere here I believe where the guy talked about his tranny swap and had some pictures posted....
I would say just do trade in for a MT, because at least that way you know all the parts are covered by warranty if you get it with less than 50k miles and they still make TSXs. Down here the 6spd ones are much cheaper than AT, you can probably do a direct swap without any $$$ out of your pockets.
mada51589
05-03-2022 08:54 PM
