PLEASE Hondata!
I am 4. I don't understand; Hondata says that the problem is that Honda will not give them the source codes or something to that effect. But how is it that they got the codes for the 04 MT+AT, 05 MT, AND 06 MT+AT. Why would Honda give all those others out, and not the 05 AT??
From this thread
There was another post by hondata that I can't find right now that described the number of combinations that they had to go through to "crack" the code.
Originally Posted by hondata
Yes. Please do not call us.
We are working on the 2005 ECU. Due to the nature of this work it impossible to give any sort of timeframe. When we get that done, it will be back to the drawing board with the 2006 ECU.
We never said anywhere that we would not make an 05 AT reflash. What we did say that we would continue to try. However we are releasing reflashes in the order that we are capable.
One option we have for the 05 AT is to provide an 04 ECU with reflash for the 05 AT. That would of course be more expensive as it includes the ECU. I would expect a price of about $1250. You would retain your stock ECU and could sell the reflashed 04 ECU at a later time.
So if i opted to just put an 04 ECU into my 05, they would obtain the 04 ECU for me? Or would it be $1250 and me having to hunt for an 04 ECU?
Originally Posted by jiggaman
i feel for ya guys, sometimes life is not fair.
Well, hopefully they've got the computers buzzing away trying to crack the code. I, for one, would prefer a proper 05 AT reflash over an expensive stopgap solution using an 04 ECU... and from the looks of this thread, there's more of us out there.
As the Hondata rep said before, they are working on it.
Originally Posted by jlukja
From this thread
Just a theory.
https://acurazine.com/forums/showthr...t=hondata+smog
Originally Posted by acuratsxms
hondata. i have an 05 AT and an 04 AT ECU that i'm having synchronized to my Key. have y'all had any problems with 04 ecu's n- 05's,. The Comptech Supercharger will work as well wont it since there is no mechanical differ. expet the ECU.
Patrick
Patrick
Originally Posted by Hondata
As far as we can see, the main difference with the 05 ECU is that it contains the VIN number of the vehicle. Some smog test stations in the future may require this VIN number. In that case you could just plug your 05 ECU back in.
The MT 05 ECU performed identically to the MT 04 ECU in our dyno tests. I would expect the same of the Auto.
Edit. From the previous post, it appears that someone has already tested that this works well.
jigga, you didn't sign in: https://acurazine.com/forums/showthr...654#post565654
taken care of now!
Originally Posted by CarbonGray Earl
Hey Jlukja, do you know if it was the manpower working on the Civic SI that may have helped to put the 05 AT on the back burner? They are now done with that, so maybe they could refocus their efforts back to the TSX while honda has nothing new coming out...
Just a theory.
Just a theory.
Originally Posted by drunkenbuda
why you say that?
like this: I hate my TSX
Originally Posted by Tsx536
If I remember correctly, the 05 AT ECU has the VIN number embedded in the ECU. Hondata was worried that the reflash could be detected when a SMOG check was performed.
Originally Posted by MTLer
Then they can still make hondata for Canadians because i don't think we have recurring smog checks like you guys...
blaze a fatty....
