P2R Throttle Body spacer
#81
^^I did install it. Fitment was just about perfect, install was easy, but taking off the old bolts was a bitch. Its a slightly noticable difference in power. Posted some of my thoughts on Chuson's thread. https://acurazine.com/forums/showthread.php?t=41326
I'm going to post my thoughts and pics this week in a new thread.
#82
where is my garage?!
1 Post
i emailed p2r regarding an updated ETA for the thermal throttle body gaskets for the 06+.
'We will be releasing the thermal throttle body gasket in a few weeks from now.'
#83
On a related note, does anybody know what the thermal gasket is made out of? Delrin? (Seems like it would be fairly easy to make a spacer of your own, especially with plastic).
#86
Former Sponsor
Originally Posted by green_henry
Does anybody know why the spacer itself can't be made from the same material as the thermal gasket (rather than aluminum)? When you think about it, the spacer is just a really thick gasket. Is the thermal gasket material too soft/flexible?
The thermal gasket is made out of a proprietary material that is used by P2R and only one other well-known company. It has better heat resistance than other materials on the market. And the gaskets come out to about $17.50 each once you factor in the shipping, CC fees, etc so it's not like they are expensive.
#87
T.DoT P.I.M.P. lol
1 Post
Originally Posted by tsx4lyfe
yo 925tsx i have 08 too just injencai nd greddy evo2 exhaust bypass valve didnt fit but wats comptech ss?
Comptech SS means... Comptech Stainless-Steels?
#90
^^john, make sure you reset you ECU after install. I swapped out my OEM battery last week, and now the car feels much different. I shoulda disconnected my battery when I installed it.
I don't know how the ECU works out airflow exactly, but it seems that having a clean read on airflow as opposed to letting it work out over time may have made a difference.
I'll probably reset the ECU when I put in the TB bypass mod as well.
Oh and be advised. Taking out those studs can be a royal pain in the axle.
#92
i just got the TB spacer and gaskets from excelerate in the mail at work. thanks josh!
now to find some time and install this thing...
#93
#94
1 Post
Cool. Which one did you order? If it's the Civic, would you mind measuring the inner diameter for me? (mine was 66mm) Thanks
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
