Oil Catch Can v2.5
Subscribe
Aug 13, 2006 | 06:19 PM
Just finished with another catch can bracket design. It uses the v1 small can and v2 mounting style and hose routing. It takes advantage of the empty area after the stock intake tube is removed. The top of the catch can stays with the bracket and the bottom part simply screws off for draining. The hose routing is better than the original v1 method to clear the PS pulley and belt.
The top of the catch can is drilled and tapped for screw mounting
Reply 0
Aug 13, 2006 | 06:31 PM
Bored today Johnny?
Looks good.
Reply 0
Aug 13, 2006 | 07:00 PM
Dude you are the man!
Can you start mass production on your mods. I will sponsor you as a vendor.
Reply 0
Aug 13, 2006 | 08:03 PM
Jtso, always impressive work.
You need to go into business, u got support here!
Reply 0
Aug 13, 2006 | 08:05 PM
Johnny, Can you post pics of your hose routing?
I'm running your 'v1' can (and thankful i am everytime i empty it) and my hose routing sucks. I mounted it over by (on top of) the washer fluid reservoir, and my return hose goes right next to the accessory belt on its way back to the engine. I really need a better spot / hose routing, so this may be it.
Thanks.
Reply 0
Aug 13, 2006 | 08:21 PM
Awesome job as usual!
Reply 0
Aug 13, 2006 | 09:02 PM
I think this is for me. I ask him to make one for me. JTso is the man! I can't wait to have them on.
Reply 0
Aug 13, 2006 | 09:36 PM
Thanks.
The hose routing is same as the v2. My v2 bracket has been slightly redesigned as well.
https://acurazine.com/forums/showthread.php?t=19219
Reply 0
Aug 14, 2006 | 05:05 PM
2 questions.
1. I don't know if I'm reading what you posted correctly. the can is already drilled/tapped for screws or did you drill/tap it?
2. did you make that mounting plate or did you buy it somewhere?
thanks
Reply 0
Aug 14, 2006 | 06:10 PM
thanks
1. I have to enlarge the existing holes and tap them.
2. I have to make the mounting plate.
Reply 0
Aug 15, 2006 | 09:09 AM
Quote: 1. I don't know if I'm reading what you posted correctly. the can is already drilled/tapped for screws or did you drill/tap it?
If you have to ask... odds are JTso did it himself
Reply 0
Aug 15, 2006 | 09:21 AM
nice job....what are you doing with the v2 can? looking to sell it?
Reply 0
Aug 15, 2006 | 10:19 AM
Johnny's allways on the go!
Reply 0
Aug 15, 2006 | 12:41 PM
Quote: nice job....what are you doing with the v2 can? looking to sell it?
I already said on earlier post saying that this is made for me. I wanted get mine done but didnt know how to do it so I ask JTso to make one for me.
Reply 0
Aug 15, 2006 | 01:09 PM
How often do you have to empty it?
Reply 0
Aug 15, 2006 | 02:01 PM
Quote: I think this is for me. I ask him to make one for me. JTso is the man! I can't wait to have them on.
you said that you thought it was for you.....I had to ask, in the unlikely event Johnny wanted to test a new version for himself before making you one.
Reply 0
Aug 15, 2006 | 03:25 PM
Quote: you said that you thought it was for you.....I had to ask, in the unlikely event Johnny wanted to test a new version for himself before making you one.
hahaha. I'm so excited about this mod and others! I wish JTso was my dad
Reply 0
Aug 15, 2006 | 04:18 PM
Quote: hahaha. I'm so excited about this mod and others! I wish JTso was my dad
No thanks!
Reply 0
Aug 15, 2006 | 05:41 PM
Looks great haha how about as a older bother haha!
Reply 0
Aug 18, 2006 | 01:56 PM
details
Ok now I'm going to sound like a complete noob but.....Can some one give me more details as to the install of this. I love the idea and understand what it does
but I don't have a ton of experience under the hood unless i made a mistake and
missed a 350 4 bolt main under mine?????
What I'm looking for is the exact hook ups for the input and out lines for the catch can. and the parts used to adapt the can to the lines. Do you have to remove any
existing lines or are you tapping them? The more details the better. I love modding my car myself but I'm still learning in the process.
Reply 0
Aug 18, 2006 | 09:25 PM
Quote: Ok now I'm going to sound like a complete noob but.....Can some one give me more details as to the install of this. I love the idea and understand what it does
Look at the earlier post and search is your friend.
https://acurazine.com/forums/showthread.php?t=19219 This is the v2 and you should able to find the original v1 thread attach to it.
Reply 0
Aug 19, 2006 | 08:43 AM
I have both versions of the thread and thats what convinced me to do it. I get the
basic principal but just wanted to see exactly where the hook ups are. Mabey
someone can import some arrows in to the pic to point out exactly where they
are?
Reply 0
Aug 19, 2006 | 08:56 AM
Stock PCV setup = PCV valve -> top of intake manifold via one hose.
Catch can setup = PCV valve -> inlet of catch can. Outlet of catch can -> top of intake manifold.
The direction flow is labeled on the catch can.
Reply 0
Aug 19, 2006 | 11:15 AM
Thanks! I guess being lazy doesn't help. After I went out and took the valve cover
off it all made sense. I'm going to home depot today to the parts. Did you also
get the adapters there? They are 1/4 nipple (threaded side) and 3/8 hose side right?
Reply 0
Aug 19, 2006 | 11:35 AM
Quote: Thanks! I guess being lazy doesn't help. After I went out and took the valve cover
I got the fittings from an auto parts store but Home Depot probably have them as well. The hose is 3/8 but make sure it's not cheap gas hose. Otherwise, the hose will collapse under vacuum. I use transmission cooler lines but they are more expensive.
Reply 0
Subscribe
