OEM intake mod
Old Mar 8, 2007 | 09:52 AM
  #81
TodaSi's Avatar
Originally Posted by feuss2
Is it worth upgrading the TB on an 04? With one off an 05/06 or something else?
You don't want an '05 TB because it's the same as an '04. You want an '06-'07 TB because it was increased from 60mm to 64mm
Old Mar 19, 2007 | 09:37 PM
  #82
eo11's Avatar
OEM Intake Mod Data
I also did JTSOs intake mod; but left the stock filter box and OEM Acura Filter as was. I just removed everything after the down flex hose and put in the 3 inch aluminum elbow behind a vent cover that I'd cut the slots open on.
Here's the before:
Here's the After:
As you can see there was a 6HP gain and a 0.2 sec gain in 0-60 time.
Old Mar 19, 2007 | 09:57 PM
  #83
eo11's Avatar
OEM Intake Mod Data
I copied JTSOs mod, except I left the stock Filter box and OEM Acura Filter as was.
Here are the results:
Before
After:
As you an see here was a gain of 6HP, and the 0-60 improved by 0.15 sec
Old Mar 19, 2007 | 10:10 PM
  #84
JTso's Avatar
Interesting results. Thanks for running the tests!
Old Jun 24, 2010 | 04:52 PM
  #85
bmwproboi05's Avatar
thx guys i was wondering if anyone did it with the stock filter an look what i found with the power of google thx will be doing this to my car this weekend
Old Nov 1, 2019 | 09:35 AM
  #86
Andre Reg Joe's Avatar
Originally Posted by JTso
Here is a relatively low cost mod to those who decides to keep the oem intake but wants a little better performance.
Parts used:
- Stock intake airbox (04-06 TSX has the same box)
- 06 TSX intake tube
- A length of 3" dia aluminum intake pipe (ebay)
- K&N drop-in filter
- Two large dia. hose clamps
Tools used:
- 10mm and 8mm sockets to remove stock intake and cover.
- Dremel tool to shape airbox interior and front vent
The process involves with replacing the intake tube, air filter, removing airbox interior ribs, and installing an air tube. The pictures should be self explanatory.
Stock lid before The Comptech Icebox lid would probably work even better
Stock lid after I only remove the large cross bar
Bottom before
Bottom after I removed as much plastic ribs as possible to create a larger space
Air tube comparison 04/05 on the left. The slightly larger dia. 06 on the right
Some basic testing results
- The post mod with stock air filter has lowered the intake temp slightly when comparing to a completely stock setup.
- Throttle response with stock air filter and stock air tube seemed slightly sluggish when comparing to the K&N CAI.
- Throttle response with K&N drop-in filter and 06 air tube is actually pretty good, and very close to the K&N CAI.
- The air intake temp is about a few degrees warmer than the K&N CAI setup.
- Interior sound level is quieter with the stock intake mod at various rpm range and throttle inputs.
- Sorry, no dyno for this one.
For some reason I can’t see your pictures posted could u possibly repost them or send them to me directly pleas and thanks
Old Nov 1, 2019 | 03:43 PM
  #87
Ron A's Avatar
Administrator
Welcome to the forums.
The post you quoted was made 11-01-2006 and the poster hasn't logged in since 04-06-2016 so it's not likely you will get a reply from him.
Hopefully, someone who saved the pictures may see your post but that's a long shot also.
Old Nov 5, 2019 | 06:59 PM
  #88
Originally Posted by TSX2345
04/05 has a 60mm TB
06 has a 64 mm TB
So the 06 has a larger tube to fit the larger TB
So how does the 06 fit the 04 if the the tube is meant for lager TB? wouldn’t I also need and 06 Tb for this?
Slow98teg
30
Jan 2, 2017 09:01 AM
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
handsom-hustla
Nov 13, 2015 05:04 PM
sockr1
Oct 1, 2015 01:31 AM
MyKids&Cars
Sep 1, 2015 12:53 PM
