Nitrous for TSX
You mise well just throw a stick of dynomite into the engine bay. I believe with the TSX a dry kit is not available. I think that the dry kits are a little more safer and reliable then the wet kits. But putting nitrous in your TSX will drastically shorten the life of your car. Plus without upgrading the internals you have a higher risk for engine failure. And we all know that there aren't many internal upgrades available.
(I agree with you, though -- there is no free lunch.)
Originally Posted by JohnnyMilano
Comments please
When the spray goes bad . . . . .
Functionally useless unless you find a way of manually increasing injector duty cycle so more fuel ends up in the cylinder to take advantage of the denser/more oxygen rich charge. Also dangerous in the same circumstance.
I personally think its funny none of u have had nitrous on a tsx and u seem to know everything about it .I have sprayed my tsx for over 6 months on a daily basis and i have had not the first problem on a 50 shot and the car pulls hard as shit ,The car breaks loose on 20's in 1st 2nd and 3rd while on the bottle .I think if its installed right and with a window switch so u dont go past rev limitor while spraying u have nothing to worry about as long as u dont spray 10-15 times a day .I personally would do it again if i had another tsx to spray since it ran so good with it .Their is 2 or more tsx's here in my town that are spraying i had a nx kit and the other guy is running a venom nitrous kit and we both have had no problems at all for the last 6 months
Finally some good news, i guess. Interesting. thanks for the info dub. i have heard of a kit which only activates when rpm's are over a certain limit. Sound familiar?
its all and how its installed and alot on the driver u can blow anything up u can blow a stock motor up with a over rev seen it done before .and when ur spraying threw a shift yeah it will detonate then blow up there is all kinds of ways to blow a motor.If you have doubts dont play on the edge if u cant handle some fun and a few risk dont do it .
from my understanding, as tsxondubs has said, it can be done. but obviously tsxondubs knows how to do it. i think you really have to be careful with it, as it's more than just a "few risk"
i'd steer clear myself. but i do have a friend who could help me do it right if i wanted to.
If, however, your TSX is a short-termer or throwaway to you, the bottle is cheap hp.
http://www.comptechusa.com/store/product443.html
this is a much safer way to increase HP and Torque.
Hope they come out with a kit for the 06 AT TSX soon. They'll get my money.
also 4 grand more so u tell me how u would want to spend that much money .I was sponsored by nitrous express anyways so my nitrous was free so i was not out any money just a comitment to attend last show season .
I agree with tsxondubs. I have a 2005 tsx I've been running 50 shot out of a 10lb bottle by nitrous express for over a year now with no problems. its a wet system. I believe they are more reliable than dry and I don't run purge so lower risk of pulling. if u get the right valves ie: low fuel pressure gauge and monitor your air to fuel ratio constantly you shouldn't have much to worry about. run seperate sylinoids for fuel and n2o. and people will tell you not to drive with it on but with auto shut off and arming switch no problems
Are you running a window switch?
mlody
Dec 4, 2019 02:11 PM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
