need recommendations on a Floor Jack for TSX
Old Oct 12, 2006 | 03:58 PM
montebello13's Avatar
Hi
new here and great stuff here, lookin at getting a Comptech Sway + Icebox soon... But before i start anything, it seems i require a GOOD floor jack for a lotta mods.
i started lookin around and found A LOT of them get bad reviews... so if anyone could recommend one (from personal experience would be best) it would help me out tons.
i just got a 2006 TSX.
i see cheap ones range around 50-80 but i would like a sturdy one and understand if it goes in the high 100s...
thanks for any help...
Old Oct 12, 2006 | 04:03 PM
TodaSi's Avatar
I have an AC jack, paid $220 for it and it's awesome......will last me a lifetime http://www.drivewerks.com/catalog/sh...ACHyd1_pg2.htm
Old Oct 12, 2006 | 04:08 PM
jlukja's Avatar
Whatever jack you get, make sure it has a lifting range of at least 17" or more. The jacking points on my 04 are fairly high off the ground already and you need to get it up pretty high for the tires to clear the ground. I bought a Craftsman that goes to 21". Works OK for me but it got pretty bad reviews (I didn't read the reviews until after I bought it).
Old Oct 12, 2006 | 04:11 PM
CJams's Avatar
Guinea Pig
If you plan on lowering it at all you want to go with a low profile jack. They have a good one at costco for like $100. JTso might be able to tell you a good make/model. He's the one that helped me with mine.
Mine is an Arcan xl-35 3.5ton low profile floor jack. It was pretty cheap and works great. My car is dropped about 2-2.5" and it works perfectly for it.
Old Oct 12, 2006 | 04:16 PM
TSX2345's Avatar
A DiRTBAG decal on my
Nice ass jack
Old Oct 12, 2006 | 04:49 PM
EndCheck's Avatar
Pick up some jacks stands while you're at it. I've heard a few horror stories of jacks giving out when a person was underneath the car.
Old Oct 12, 2006 | 05:26 PM
thanks for the quick reply guys
lookin through the posts and links i saw a FULLY RECOMMENDED one for like almost 300...
also saw the arcan Costco one, but it seems people have problems dropping the car back down... i want a worry-free one.
edit: oh yea, i was lookin at getting the stands too, thanks for the reminder...
Old Oct 12, 2006 | 06:12 PM
peter_bigblock's Avatar
C'mon, man! Row yer own.
I bought Sears' Craftsman Professional high-lift SUV jack (max 21" lift) and it works great, especially hitting the TSX's rear-center jacking point if you're trying to put the rear of the car up on two jack stands. It was $70-ish and works great.
Old Oct 12, 2006 | 06:41 PM
kaikai114's Avatar
Got Milk???
I got a Craftsman Aluminum racing jack, good for carrying it around to tracks if you need it. And lifting range starts from 3" from floor height, pretty good if your car is slammed, but it aint gon work if you're slammed like CCC
KC
Old Oct 12, 2006 | 07:07 PM
CJams's Avatar
Guinea Pig
What problems do they have dropping the car back down? It works the same as any other jack. You twist the handle it and it brings it down as slow as you want
Maybe it's operator error... never had a problem with mine
Old Oct 12, 2006 | 07:29 PM
CCColtsicehockey's Avatar
if you do a search there is a 3 page thread about jacks already.
Old Oct 12, 2006 | 07:42 PM
JTso's Avatar
I have two jacks from Costco and have been using them on a regular basis for the last few years without any problems. Both are low profile, high-lift jacks. One is a heavy duty 3-1/2 ton and the other is a 2 ton light weight. Both will lift up to 21" and clear my TSX lowered 2" with the OEM front spoiler. Both have wide wheels and wide saddle for stability. The aluminum jack is about $100 and the heavy duty one is about $70.
Old Oct 13, 2006 | 12:19 PM
thanks
yea, i figured it was just operator error, i just wanted to see others say so, especially from personal experience
thanks guys
haha i already got the dreaded "do a search you idiot"-reply
thanks, my dad has a tacoma too, so i'll probably go with the heavy duty one from costco, thanks guys!
Old Dec 21, 2006 | 11:04 AM
llJrockll's Avatar
Rebourne
Okay, so I just recieved a $50 gift card from my employer. I have had in mind in buying a low profile jack. I checked out costco, but they only seem to have one low profile jack which looks pretty good and it's only $99, but the maximum height range is "14.76 inches . Would I need a higher range for my car. I'm lowered and I think a low profile jack would be great.
I'm assuming Costo has more "Jacks" off hand directly in the store, have any of you been there lately?
Old Dec 21, 2006 | 12:03 PM
JTso's Avatar
Don't just look for low profile. Make sure it's high-lift as well. Otherwise, you will have problem jacking the rear up.
Old Dec 21, 2006 | 12:05 PM
tsx 2 nv's Avatar
ridiculously good looking
i use this, in cunjunction with my oem car jack:
http://www.sears.com/sr/javasr/produ...0100383&AFFL=Y
it gives me much room to crawl under my car.
edit: even though it got bad reviews, it has worked fine for me....i guess i shouldnt recommend it
Old Dec 21, 2006 | 12:16 PM
tsx 2 nv's Avatar
i think im gonna throw away my jack, and get the coscto one.....
how do i get rid of my floor jack? i cant just throw it in the trash can can i?
Old Dec 21, 2006 | 01:27 PM
LoveMyTL-S's Avatar
You can give it away to a friend or relative or if all aluminum, put it in the recycle bin.
Old Dec 21, 2006 | 09:05 PM
Black_6spd's Avatar
VSA Rocks
Also, I'd like to add that for A-spec guys, they need a jack design that has a long distance between the lifting point and the lever. Otherwise, the handle will hit the front lip when trying to use the front jacking point.
Old Dec 22, 2006 | 09:03 AM
tsx 2 nv's Avatar
i dont want to give a friend or relative a jack that is bound to break.
Old Dec 22, 2006 | 11:48 AM
JTso's Avatar
You can still use it for other things like changing tires, supporting an exhaust system during installation or raising the suspension during bolt tightening process. I have two other regular jacks for those functions.
SidhuSaaB
May 30, 2020 12:40 AM
acura_dipset_tl
Jan 1, 2016 03:02 PM
BIGxRED
Sep 26, 2015 02:16 AM
navtool.com
Sep 25, 2015 05:15 PM
