Need help installing metal bushings for short shifter
I got the comptech short shifter but these metal bushings that i bought on the club rsx site is no help to install on my acura.
I need some pictures or something to know where these bushings go and how many go where. Can anyone help me out??
thanks
thanks
A-spec Arctic Blue
thanks
thanks
You should have received a total of 8 bushings. 2 bushings go where the original rubber one is located (one on the top and bottom). If you go to the ClubRSX thread within my thread, you will see the placement of the metal bushings. Even though it is an RSX, it is still located in the same place. I would follow the neuspeed instructions to install the short shifter.
I'm just funkin around...
this might help you... just installed my metal bushings today... good stuff ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
https://acurazine.com/forums/showthr...=metal+bushing
Is this a simple install if i am install the SS?
A-spec Arctic Blue
Look at Steps 11 - 13
You don't need to remove the entire shifter. As mentioned follow the Neuspeed short shifter instructions.
Originally Posted by sigmachi96
A-spec Arctic Blue
Follow the Neuspeed instructions.
When you remove the four bolts of the shifter, you should be able to pop out the existing rubber ones and replace them with the metal bushings w/o having to remove the entire shifter all together.
A-spec Arctic Blue
so there are just 4 used instead of 8?
You use all eight. One on top and one on the bottom for each bolt (2 x 4 = 8)
We have the same shifter, i am wondering iif the bushings will work too
i think its the same one as the TSX but if you look at the picture i belive it the same bushing replacement
http://www.hondaautomotiveparts.com/...LEVER+%28V6%29
Here is the link for the TSX shifter .. Notice it is missing the RUBBER, FLOATING
http://acuraautomotiveparts.org/acur...prddisplay.jsp
It looks the same , maybe the honda could benifit from this ? please help
http://acuraautomotiveparts.org/acur...3SEA01_B34.gif
here is the 6mt on the honda
http://www.hondaautomotiveparts.com/...dn01_b3401.gif
Bye TSX, hello domestic?
I kinda lied i have a Honda accord Coupe V6 6MT but i did find out that the comptech short shifter will work with my car. Even though its made for the tsx.
one is the honda shifter
the other is the acura tsx shifter
Now look at where the bushings go.
do you think they will work.
I am missing one part
Originally Posted by JTso
So, if the Honda one doesn't have the rubber cushion, does it mean the mounting is already regid? Does the stock shifter housing move when moving the shifter?
I dont think i should risk messing with it
I need some expert advice
cycdaniel
12-17-2019 10:58 AM
asahrts
09-04-2015 05:55 PM
