Just a little help please
Old 02-02-2006, 10:54 PM
'05 abp tsx
Equalizer's Avatar
I'm just jumping into messing around with my car (its been bugging me since the november meet in SoCal) and ive scoured the forum for answers but... I have some questions the search function isn't helping me with
(1) How does the stock intake work in relation to the resonator?
(2) If im looking to a short ram-like DIY type mod, what is the best way to secure a filter to the stock intake tube?
(3) What is the best way to direct airflow to a short ram?
(4) What is a "drop-in" filter setup?
I've ruled out a full CAI, and am thinking of the most economical solution to modding my intake...any help would be great! >>noob<<
Old 02-02-2006, 11:24 PM
balwinderismyuncle's Avatar
The resonator is a plastic thing that blocks the air, remove it, more air flow, and more noise.
Use clamps, I guess. Those metel ones that people use to clamp hoses in the car.
Maybe a pipe from Home Depot, that flexed. Put it in the front of the car, where a lot of air will come from, and point it to the intake.
You put a filter into the stock box.
Old 02-02-2006, 11:29 PM
B A N N E D
925tsx's Avatar
get the icebox
Old 02-02-2006, 11:39 PM
She said: it's GINORMOUS!
mg7726's Avatar
remove the resonator
Old 02-02-2006, 11:54 PM
'05 abp tsx
Equalizer's Avatar
is it better to put the filter into the stock box, or remove the box and have the filter hang?
Old 02-03-2006, 05:06 AM
moda_way's Avatar
If you are talking about a CAI, then that is better because you have more cubic inches to draw from.
Regardless, you'll need to remove the resonator box which is behind the driver side front bumper... do a search if you haven't already and you'll find plenty of info about it.
Old 02-03-2006, 11:59 AM
Its easy to remove it too. You dont even have to take off the wheel
Old 02-03-2006, 12:13 PM
Rep'n Taxbrain.com
Tsx536's Avatar
Look for a thread by Peter_BigBlock. He did a DIY intake and has a good thread out there about it.
Old 02-03-2006, 12:24 PM
ABP TSX
gsclifton's Avatar
https://acurazine.com/forums/showthread.php?t=19933
Scroll down and you will see all kinds of pictures of the resonator.
https://acurazine.com/forums/showthread.php?t=26823
Something custom fabricated most likely.
K&N into the OEM box replacing the OEM filter.
Old 02-03-2006, 07:53 PM
'05 abp tsx
Equalizer's Avatar
thanks thanks! sorry im so noob...just a quick follow up
In the link above, Kaikai removed the resonator chamber and the airinlet/Jtube. in that diagram, there are still two tubes Parts 9 and 10... do i do anything to those/ where do those go?
I'm a little confused by my searches... With the Filter up top, I'm looking a short ram set up? The options I see so far are attaching a cone filter like Peter_BigBlock or an icebox (with or without a lower air horn?) or a drop in filter in the filter box(cone or flat filter?) It seems like it would do little to replace the stock air intake tubing...
thanks!!!!
Old 02-05-2006, 12:41 PM
'05 abp tsx
Equalizer's Avatar
help, please!
Old 02-05-2006, 01:04 PM
Just dial 1911
joerockt's Avatar
I really dont understand why people spend 30K on a car and then go ghetto/cheap on mods.
Dude, dont try to rig it like this. If you just buy an SRI setup, you wont even have to remove the resonator...
Old 02-05-2006, 02:16 PM
Future TSX owner?
Kittah's Avatar
seriously man just buy a SRI or CAI if you dont want to buy spend that much money on buying a real intake just buy a freaking used one!
Old 02-05-2006, 05:17 PM
CCColtsicehockey's Avatar
Received 3,860 Likes on 2,580 Posts
really please people. this isnt a civic so dont rig ghetto ass cheap mods for it like it is one.
Old 02-05-2006, 05:20 PM
either buy one of these
1. Comptech Ice Boc
2. K&N Inktake
3. Injen Inktake
or dont mod it. dont make some PVC pipe intake this isnt a civic
Also why have you ruled out a Cold Air Intake.
Old 02-06-2006, 12:04 AM
CivicEx1998's Avatar
Not necessarly economical but called band for the buck mod.
My own experience with short ram, is that they usually lose low end torque, off the line power, where im think is most needed.
Since u are not in to CAI, then removing the resonator can be benificial then a short ram IMO. But can be complicated if u never done any DIY on ur car. For me , i took off the bumper for ease access, and it was pretty easy and fun job. Dont forget to get a flexible pipe to get air from behing the bumper.
I will consider a short ram only if i can somehow block the hot air under the hood.
