intake and warranty
#41
Originally posted by accsueprstar
you can make your own CAI for alot cheaper. basically with the stock set up and the CAI, the main difference is that the stock plastic and rubber retain the heating alot more than the CAI aluminum tubing. Althought the injen dyno seems a bit high there is no doubt that you will at least squeeze out at least 5hp to the wheel.
My intake piping should be coming in sometime next week. I ordered a 180 degree bend mandrel aluminum pipe from jcwhitney and will instlal it on my tsx when i have time. anyways whole project will cost me around 70 bucks
Also, I've never owned a CAI, but I thought most of them were aluminum coated plastic or is that just the cheap ones?
Anyway, if some of you are getting impatient to know, it takes like 5 mins to remove the bumper, another 10 mins to remove the resonator if you don't know how to pull on stuff, and then another 10 mins to line up and put the bumper back on. Try the car without the resonator once... You'll be pulling it out for a CAI anyway.
#42
the whole plastic vs. metal is a big time debate. It basically comes down to this. Plastic takes much longer to heat up, but once it does it retains heat and thus passes it on to air in the tube longer. I guess it probably depends on the driving situation which one is better. A metal tube wrapped in insulation might be the best solution possible.
#44
i think the overwhelming heat in the engine bay will over ride any cold air coming into the intake. With this in mind the intake tube will heat up and stay hot when the motor is running. This is why i feel plastic is a better material to use for intake construction.
BTW- Iceman, honda, mugen and comptech all use plastic intakes. I am super happy with my comptech icebox on my rsx-s
rcs86
08-02-2016 06:52 PM
