Injen Intake Questions - Squeak?
Jewdacris!!
I installed my Injen two weeks ago...the other day i noticed when i am driving, if the revs are at 2500-3000 and i step on the gas there is a tiny squeak from the intake then it goes away...does anyone have an idea of what this could possibly be?
Jewdacris!!
damn, hahaha, cool, the only thing i can compare it to is a car that has belts that are slipping and they squeak its like that just not as loud.
Registered AssHat
Although make sure your rubber pipe mounts (a.k.a. VibraMounts) aren't super tight...just enough so they won't rattle.
Could it be a hissing sound and not a squeaking sound?
I had an AEM CAI in my old car, plus a short ram intake before that...and they both had a small hissing sound lower in the rpm band...it might be normal...
then again i dunno...i havent done anything to this car yet and may plan not to...
my brake pedals have a small hissing sound when i depress them slightly tho...i wonder if anyone else has had this problem and if it goes away after a while?
Registered AssHat
Originally Posted by cmf
Might want to see if a snake got in the car, with all the hissing! I don't think I've ever heard a car hiss!
hahaha...one day i might grab the shifter and feel something bite back! would make a great theft deterrent though, but no one can drive the car!
LFMS - i might be hallucinating from too many lancer evo videos...
Jewdacris!!
Originally Posted by Lung Fu Mo Shi
All I'd say is to make sure that all the fittings are tight. There may be an open joint and air is whistling through.
Thanks,
Ill check it out this weekend make sure everything is in thier correct
I hear hissing too, is this normal? or could this be an open joint? I had Intake for four days now...I'm loving it!!! but little hissing sound got me worry a little bit.
SHIFT_over.so.I.can.see
not to worry, hissing on a cone filter intake is pretty normal. the change in pressure sort of whistles through the mesh on the intake filter... you should notice a similar hiss when you turn off the engine or on a throttle blip in neutral.
Bye TSX, hello domestic?
I've heard a V6 w/ CAI hiss, but never on my TSX. You might want to check under the hood to see all the fittings are tight, and actually confirm the hiss is from the filter and not the piping
Jewdacris!!
Yeah i played tih a couple of the fasteners bbut still have the hiss...it almost sounds like air is squirting out through a fitting or something. Its hard to explain. If we all get together for the group install fest ill try and see if i can duplicate the sound.
Jewdacris!!
Originally Posted by Dan Martin
When do you hear the hissing? I hear a little suction noise if I blip the throttle at a stop.
It mostly seems to happen if you step on the gas, between 2500-3200 rpms. Its just a tiny squeak... I dont know if it is air trying to get out of the piping or what. Its not increadibly loud, and the car doenst feel any different. Id just like to at least know what the sound is.
I had Intake for five days now, I don't think car wash can ruin filter right?
May be I got used to hear loud Growl for five days and feels like it's stock now.
