View Poll Results: Which modification would you choose for a stock 2005 AT TSX
Voters: 34. You may not vote on this poll
Increasing Torque Poll Thread
Hey guys,
A little up to my previous thread anyway as you may or may not know, my new rims are adding extra weight to my vehicle I am trying to free up some torque and responsiveness, I have narrowed it down to either a set of headers or a three piece pulley set. Which would be best for my 05 Automatic TSX?
If you choose other please state why.
Originally Posted by Jim Holloman
What is a "Three Piece Pulley"?
Why would a "Three Piece Pulley" increase available torque?
https://acurazine.com/forums/showthr...t=piece+pulley
Someone stole "My Garage"
I have both mods and I'd say DEFINITELY the pulleys, especially in any RPM below about 5K. They give a 5-10whp increase from probably 1500rpm and up... it's basically 5-10 constant whp across the entire range.
Thanks for the info guys, looks like I am going to be placing an order for a set this week hopefully thursday once I get paid, I was going to orignally spend the money on a front (oem) lip plus fogs, but who cares about aesthetics anyway, and ya 925, if you cut me a great deal I wont turn it down.
Originally Posted by ThirdLane
I highly doubt a under drive pulley set will free up 5-10whp. Probably 2-3whp at the most
where is my garage?!
1 Post
i'd actually say the headers if it's between the 2. i'd imagine the gains from the headers would be more significant than the pulleys. but not to take anything away from the UR pulleys. they're great. you feel the car rev a little faster/harder.
of course if you want to really free up the air flow for more gains, the intake/header/exhaust/higher flow cat would yield some good gains. since you have an 05, this might be a good route to go to free things up since the 06+ have a little better air flow vs. the 04/05's.
I would go headers and High flow cat. Pulleys would be nice, but they are hard to install, and reading threads about removing the crank pulley (harmonic balancer) it could possible mess up your engine. I just pulled mine for my rebuild, and that bolt is on there good. It took me and two friends with a long ass breaker bar to break that sucker loose. I have never heard of headers hurting a engine, and even if the pulleys are safe for our cars, just that 1% chance of messing things up I wouldn't do it. Besides with the pulleys you better buy a better battery too, because that thing wont be charged like it is now.
Originally Posted by GTSX-05
Have you searched it has been discussed, if I picked up 925's headers swaped out the flex-pipe, would I see a decent gain across the board, or would I need to do this in conjunction with a high-flow cat, can anyone point me to the right direction of where to purchase?
Get a K series stroker kit. That'll help with low end power. Bolt-on power adders will not net you much on a Honda. Its not like a Chevy small block when you bolt on a exhaust system and you gain 20-30hp
CL9 ABP
I did headers and it was def a better breathing car, then i got pulleys which made pulling more .
Plus i did a highflow cat and hondata. so if you want more power look at the route of hondata.
Pulleys truthfully aren't that hard to install. Just have the right tools (breaker bar + some impact extensions to daisy chain the bar outside of teh wheel well), a strong jack handle to get leverage on the breaker bar, and some impact sockets. An impact wrench definitely helps with the bolts on the Alt and PS pulley (just use the old belt to hold the pulley while you blast it w/ the impact), and some patience.
Header is also fairly easy but will not really increase your low end at all.
B A N N E D
its a pretty good deal as is considering the options.
as far as exhaust mods, i only have the header right now and you can definately feel the difference
to me that seems like a lot already, but what do i know :/
Well if you aren't up for the fun and challenge, then pay someone. Personally I like the garage time -- it's "me" time away from my wife for a bit... LOL!
joflewbyu2
10-08-2015 11:16 AM
SUPRMN84
10-07-2015 09:46 PM
STL TL-S
09-23-2015 08:52 PM
4drviper
09-23-2015 07:42 PM
