Hondata - VTC Cam Timing
Skater, Gentleman, Sniper
Is there anyone out there who has implemented the 45 degree VTC mechanism? is this mod comppatible with a standard Hondata reflash or no?
Yeah, there are a few out there, but the consenus says that it's pretty much worthless without a race header.
The two biggest stumbling block on this site are the cost of a race header and "practical" use of kpro.
While there are many swapped-K24's running either the RSX-S VTC or a machined TSX version, I believe only poster "Shaang" and Doug of Hondata are running one on the TSX chassis.
Of course, this doesn't include the Grand Am TSX's.
Out of curiousity, I decided to check how much it would be to buy a new VTC and send it out for machining:
Item #7 shows the VTC assembly which includes the sprocket.
14310-RBB-003 ACTUATOR ASSY., VTC (46T) 1 2005 Acura TSX 135.68 108.54
It's the same part number as the '06. I was hoping that it was a different version that had more than 25 degrees.
Originally Posted by Redfish
I think the RSX is 50deg, right? May be too much advance, potential damage.
I would think that Hondata could customize the reflash for this, right?
The stock ECU doesn't allow any more advance than 20 degrees of the VTC mechanism. Mine is a modified TSX VTC mechanism to 45 degrees, rather than a stock RSX one which has 50 degrees of play. Anything more than 45 degrees on stock 04-05 pistons and you'll have valve/piston contact issues.
"Allowing the full 50 degrees movement leads to a greater risk of valve to piston contact should you accidentally mis-shift and over-rev."
http://www.hondata.com/tuning_k24a2_tsx_engine.html
^ yea that's the only instance of a 45 degree limit I've ever read.
Maybe if the engine is tuned and the stock rev limit is kept it'll be a non-issue?
If it was me I'd probably stick with the 45 degrees just to be safe :p
Yes, I discussed it briefly with Doug himself when we were tuning my car. I also discussed this w/ John at Hytech when we modified my VTC mechanism. I'm still running it right now, but it only has 20 degrees of play... that is until I get k-pro.
As you may already know, John does a lot of the work on the Grand-Am Cup TSXs. I would consider any input from him to be SOLID.
urbtsx
03-04-2017 06:53 PM
