Hondata re-flash
Hondata re-flash
Had my TSX re-flashed in August of 05. It is a 6MT. Also installed an Ingen CAI at the same time. Have had the car to the track (Summit Point in WV) on 2 different occasions since the reflash. Here is the problem.
When I had the reflash done, I could tell quite a bit of difference in the performance, now it seems to be the other way around. Car doens't seem to perform as well and is not as fast. Also seems to have some hesitation when accelerating either is a curve or straight away.
Is anyone else having the same issues?
C'mon, man! Row yer own.
I've noticed that I'm used to the power-band flattening of the Hondata reflash. Don't forget, it doesn't raise your peak power, just smoothes and lifts the upper-middle part of the hp & tq curves. I also think one has to add headers and, quite possibly, high-flow cat to get the most out of the reflash.
I don't know what that would be -- maybe the reflash, maybe a fuel-system problem or fouled plug? Is it throwing any codes? What RPM/gear is the hesitation happening?
I wonder if disconnecting the negative terminal for 30+ seconds and allowing the ECU memory to reset, so to speak, makes any difference. I have read on the superhonda site that this is something people do from time to time with Hondas. The TSX's ECU is adaptive, I know, but it is a computer after all and -- using my p.c. as a terrible analogy -- sometimes they just like to be turned off and turned back on.
Beyond that, since you're working with Hondata it sounds like you're working with the right people. Just some suggestions off the top of my head.
this can happen on both a straight away or coming out of a turn. This was not an issue before re-flashing the ecu.
Thanks for the suggestions.
Rep'n Taxbrain.com
Originally Posted by brewcrew1921
the hesitation happens primarly when I have run the RPM's to around 6-7K and then shift. There is a brief hesitation, like a mis or a loss of power for a mili-second, then it is fine.
So you have a 6MT?
Yes it is a 6MT. When I shift the RPM's drop down to about 4500 or so.
In stock form, the vtec engagement is 6000 with the rev-limiter set at 7100.
Originally Posted by gavinn58
You have to stay above 5000 to stay on the vtec cam with the reflash. to get the most out of my reflash, I shift at 7500, rev-limiter has been raised to 7600 with the reflash. My revs then drop to 5200.
Originally Posted by phirenze
Also, get a header. From what i've heard, the reflash is most benefited by one.
Rep'n Taxbrain.com
Originally Posted by Stokeless_TSX
=( im still waiting on a K PRO....
urbtsx
03-04-2017 06:53 PM
mrkingstonvi
02-22-2016 01:53 PM
k6biv
09-10-2015 06:37 PM
