Question about CAI...
I was thinking that CAI would get its cool air from the wheel well. But CAI intake is made out of metal right? So the metal would absorp all the under the hood temperture...so it wouldn't get all the cool air but warm air. Wouldn't it be better if you can cover the shiny polish part of the CAI intake with some sort of insulator to protect it from the heat in side the hood? Just a thought....
Ever picked up a hot potato wrapped in aluminum? There are two parts to a CAI. The reflected coating is intensional (radiated heat) and the fact that the CAI tube is molded out of plastic is important too.
As JTso mentioned, there are other sources of heat... the TB has coolant running through it as does the head right next to the intakes. Both of those are areas that should be considered for improvement.
Originally Posted by HoRRo
ummm.....that's a bad metaphor. a hot potato is hot regardless, but if you take the aluminum off the hot potato, the aluminum cools super fast.
Potato = engine compartment
If you run a solid aluminum CAI, it will radiate heat. Aluminum is not a good insulator, rather a good conductor. The CAIs are plastic on the internals and coated with an aluminum like substance. I'm only answering the part about the fact that the CAI isn't metal, just has a metallic finish.
ah, ic..... is the Injen CAI for the TSX plastic on the internal as well? I can only find pics showing the opening and not directly inside, from those angles however, it looks like only aluminum piping.
hmmm....... was doing a little google'ing, the RS series Injen CAI's are made with 1/4" thick 6061 T-6 aluminum, which is like 63.5mm, I think the Injen is all aluminum? Anyone with Injen CAI can confirm?
That's messed up??? I believe you, but there must me a component of the air inside the intake that acts as a buffer to the cold air then.
navtool.com
31
Nov 16, 2015 08:30 PM
DerrickW
Nov 15, 2015 05:52 PM
