Hondata Heat Gasket for TSX
hondata is looking for a tsx to test fitment of a heat gasket. cmon honda ecu upgrade!
http://www.hondata.com/
Wonder wht are the differences b/w intakes and heat gaskets. hondata say it is about 5% increase in power so thats roughly ~10Hp gain. i think its a much better value than CAIs. i may opt for this.
well as far as performance per dollar, the heatshield is supposedly better. however intake is still one of the best bang for the buck mods you can get so why not just get both?
actually i HATE modding my car. guess since im alil older now i dont really like lowering my car, adding intakes, and exhausts. I may or maybe not even do the hondata thing unless it gives the tsx som moree low end torque. kinda of odd that im even thinking about the mugen SS, but it does give it it alil sportier look, something along the lines of the stock IS and 3 series.
Kickstand
Originally posted by 21_in_az
worse gas milage, would be my guess.
Do I Make You Horny?
Originally posted by JTso
How do you figure? There isn't any bad things about the heat gasket except it's a little thicker (approx. 3mm + 2mm washer) so the stock studs may or may not be long enough. Certain applications require longer studs but most don't. The last I heard they have stopped shipping the gasket with the washers so it may not be a problem anymore. The good things is you never have to replace another intake manifold gasket, as it's reuseable and it doesn't need any sealant to install.
more hp=less mpg.......simple fisics man.
your big words dont scare me! i laugh.....hahaha
I'm sorry that you are so misinformed. It all depends on how the "more hp" is achieved....
Not necessary. For an OBD2 ECU (which the TSX has), as intake temp decreases, fuel increases, as well as ignition timing. The engine behaves a little peppier with less throttle. Don't get me wrong, the gasket alone is not going to make the car faster. It's just one of the components that compliments other mods that one would add their setup. It's just like the Hondata reflash that enhances the typical intake/header setup.
....For an OBD2 ECU (which the TSX has), as intake temp decreases, fuel increases, as well as ignition timing. The engine behaves a little peppier with less throttle....
common sense says that when fuel increases, so does mpg.
were not talking alot worse, like 1mpg worse, maybe 2. i was saying that the ONLY con to doing this mod is that you will lose just a little mpg.
common sense says that when fuel increases, so does mpg....
Audi Driving Snob
oh, sorry i didnt know it was possible to tune a heat gasket.
my fault.
my fault.
Now while i don't think the gasket will give you any increase in efficiency something like a hondata ecu tune can.(it's used in conjunction with a CAI)
It is correct however that with an i-vtec system you can feasibly get more power(more advance) while using the same or less amount of fuel. The change in temp in this case probably isn't enough to have this effect but it is possible.
my fault.
my fault.
Here is pic of a race gasket and the cut out area.
www.boyzaudio.com
i am more interested in their ECU upgrade than the headgasket. yes, it's nice. but i am not sure how much diff it will make for regular everyday driving. besides, i found it a pain to get it installed when i helped my friend to install his on his si hatch.
i cant wait untill both the heat gasket is out, and the reflash!
combined with the vafc-ii hopefully we will have the same power as a v-6 accord......*heres hopeing*
Stokeless
400 whp is the goal i will achieve this one day..even if i dont get the hondata reflash...i can do it with just the vafc II if i ever get the harness...
I spend 2 much time here
stokeless i would think that you'd be better off selling your TSX and buying a TL if that's the kind of horsepower you're after. save yoursef alot of money and headaches and blown engines.
