Hondata 05 ECU?
Hondata 05 ECU?
I understand their is a difference in the 05 ECU's for the TSX and RSX and that of the 04 ECUs. i know that some people have the 04 ECUs in their cars but i'm alittle shakey on that. Does anyone know when and if it is ever possible for Hondata to do the work on the 05 ECU. i understand the problems because i read them on their website bt has anyone heard anything about it all. THANKS
TRUST ME Dan.. i'm sitting with my hands tied behind my back because i really want to go go.. But... does anyone have any news about the date or how it is goin for hondata
The 04 ECU I am using works just fine. Can't see a reason why you'd want to hold off.
Plus, having an 04 ECU on the side allows you to keep a stock ECU around when you need one.
It's not a bad idea.
CEO of IMHO
Thanks,
Jon
tekn0mage said this
"Of course I can feel the gains, the engine for the 04 and 05 are completely identical.
The ECU is the only difference, and since it controls the Engine only, you aren't in any forseeable danger of using an 04 ECU instead of 05.
My advice is, go get yourself an 04 ECU from a junked/wrecked TSX. Send it to Hondata along with your key and immobilizer. That way you'll always have a stock ECU to fall back with.
Keep in mind however, that once you send your immobilizer, your 05 ecu will not work any longer. It will need to be re-keyed, this can be done at any Acura dealership. But if you can't wait for Hondata... this is your best shot."
Top notch 6MT
Originally Posted by acuratsxms
how do u know the 05 ecu is comming out in August
iamhomin wasn't serious... he was being (or trying to be) funny
I sent my 05 ECU a few days after they began offering the TSX reflash. I was apparently the first 05 ECU that Hondata had worked on. Upon discovering a problem with the reflash, they contacted me and gave me a list of options (thanks Doug!). The option I chose was to flash an 04 ECU and use it until the 05's are "flashable".
Like I said, it's not a bad idea to have a flashed ECU and non-flashed. In case you want to go back to stock, you can easily do so without the downtime.
Also, there are no drawbacks that I can see from using the 04 ECU. Since the engine did not change, there should be no compatibility issues with an older ECU.
None to be discovered yet, anyways. :-p
If you can, go grab one, get it flashed.
so getting an 04 ecu doesnt make the 05 ecu that you have out of the car cra not work anymore? i thought when one sends thier immobilizer and (used)04 ECU, the 05 ecu will not work any more...can anyone help me out with this and clear some things up...i really want a reflash!!!.ii'm going to call hondata hopefully monday if someone doesnt know the answer.
i'm comptely lost.so does that mean that if i send you an 04 ecu and my immobiliser from the 05tsx.. that my 05 ecu will not work? what is ya'lls progress on the 05 ecu?
I do believe using a different ECU would make your current key/immobilizer invalid.
The 04 ECU was provided by means of a temporary fix because I was sort of the first guy that sent an 05 ECU in. Upon discovering the problem, Doug @ Hondata quickly made sure my car was back up and running with minimal downtime. It involved using an 04 ECU.
After getting a good comfort level (at the time I was a little skeptical) I decided to go with it. Now after about a month of driving on it... I am convinced that it was the right move. If you have an 05 TSX and want hondata, time to go shopping. I am certain you can find an 04 ECU. I just saw a salvage TSX on Ebay the other day... they are out there.
ok i just called hondata and the guy said as of right now there is nothin for us 05er's. he said maybe later and that would consiste of an k-pro which is a new ECU all together. i asked him if i were to send him an 04 ecu with my 05 imobilizer and key if they would reflash the 04 ecu and he said "we do not do that" so... tekn0mage you are LUCKY and or what is the situation with the 05 not being used to reseach and developement... does anyone ever get a solid answer out of hondata
Top notch 6MT
What Hondata did for him was kind of an experiement at first... even tekn0mage himself said he wasn't entirely comfortable in the beginning, but now he has absolutely no regrets with using a Hondatafied '04 ECU in his '05 TSX
Though I thought the Hondata rep. user (sorry, forgot his real name... is the Doug?) has written on a-tsx that if '05 user can find a '04 ECU, send that in with the '05 imobilizer and key, they can do it no problem. The imobilizer and key on '05 are NOT different than those on '04, so to Hondata as long as the ECU is '04 (flash-able), should make no difference to them. Anyone to confirm that understanding???
cycdaniel
12-17-2019 10:58 AM
mrkingstonvi
02-22-2016 01:53 PM
