Hoen install
Hoen install
Did a search, got some results that didnt help much.
How exactly do i put these bulbs in.. the instruction manual from handa accesory is a little general, anyone have a simplier ,easy-to-read version for car tards like me?
She said: it's GINORMOUS!
if you have the car jacked up and looking up at the fogs from the ground, there is screw right next to the adjustment point, remove that; then there's another screw to the top (on the side of the bottom grille) horizonal position you need to remove.
pop the fog light and cover out, disconnect wire; turn counter clockwise to remove bulb.
ps, which model hoen h11 did you get?
Originally Posted by ricecake
I have nothing to add, just waiting for Dan or domn or Clutch to show up with handy dandy, hand drawn pictures to help you again.
That's what im waiting for...
As for the bulbs, i have the ones everyone told me to get, still not sure bout those directions but thanks.
Aftermarket fog light bulb.
https://acurazine.com/forums/showthread.php?t=2943
Links to his pics don't work though.
Ok guys, i finished, took me a while but i was doing it with no light in 30 degree weather. I have a problem, the washer screws from the bottom, both of them i coudlent screw back in and are stuck in the car somewhere. Is that bad, where can i find replacement ones?
Master Graphic Artist
I do want to see pics showing how close the bulbs match the hids. Just be careful not to leave the fog lights on too long when taking pics if you have that clear film protector stuff or they will discolor on you.
EDIT: Maybe try the dealer for replacement screws.
Yea, the bottom one does help secure the foglight in, but i got the one from the side in, and when i was installing it, i forgot to take the bottom one out at first, and i coudlent get the thing to budge, so i think it's quite secure in there.
I will take pictures soon.
and ill try to give a good writeup.
cycdaniel
12-17-2019 10:58 AM
sockr1
10-01-2015 01:31 AM
pistacio
09-26-2015 09:45 AM
