Help! I can't get this damn thing off...
Design By Force
Trying to install my comptech short shift kit, and I can't seem to get the cupholder/housing around the shift boot off. I broke off the small trim peice around the shift boot just trying to get it off. There just doesn't seem any way to get any leverage to pull the thing straight up. The clips seem like they just don't want to give, has anyone taken this panel off, and if so how did they do it?
Registered AssHat
The first two are underneath the rubber pad in the armrest storage.
The other two are attached to the "this is not an ashtray".
To get THAT out, you'll need to just pull on the other storage bin just above. Reach inside, push your fingers to the outside (left and right) and pull. It'll pop out.
I MAY have this wrong. And I've sold my Helms manual.
Registered AssHat
Originally Posted by Dan Martin
No screws, just clips. There are two screws holding the not an ashtray in but none holding the center console.
Photography Nerd
If you're still having trouble getting it out you can CAREFULLY pry the console out with a wide flat screwdriver. It helps to put some tape over the end of the screwdriver so that you don't scratch the plastic. Go super slow and just be extra careful to not scratch anything.
Bye TSX, hello domestic?
this was my method. grip inside the shift boot and get the front end out. You'll have about half of the console out.. that's the easy part. Then grip between the cupholder and e-brake and pull straight up. Make sure you aren't bending the console too much. It is a major PITA to get out, I broke a clip, but nothing on the outside luckily.
VP Electricity
1 Post
I have found that being right-handed, I do much better with this if I am in the driver's seat. In the pass seat, I get lousy leverage.
Make sure the NOT AN ASHTRAY door is open.
Oh, and pretend it ain't your car - that always helps.
Design By Force
Thanks everyone, i'll give those a try. The problem is the leverage, and i was going to use a flat head screwdriver, but i was afraid of making scratches... there is barely any gap for me to fit one in. The tape sounds like a good idea, ill give that a try first. I heard that this is the hardest part of the short shifter install... anyone else run into any other trouble?
Just dial 1911
1 Post
The only other gotcha I can think of is when you have to undo the 4 bolts that hold down the shift column, there is one that is difficult to get to. I was eventually able to get a socket on it, but if you have a small adjustable wrench that might work.
The right tools make the job easier. I went to sears and purchased a nail remover. It has a small hook like nail remover on one end but the other end has a 1 1/2" wide very thin slightly curved blade for prying. It fit in the space between shift panel and the center console giving the much needed leverage to get that panel off without marking or breaking it. Came out no problem. I would have put a pic in here but I dont know how to put a pic in the damn thread without hosting it on my site.
Puma Jim
20
10-20-2016 11:59 AM
