Help with HKS Circle Earth Ground Wire Installation
Please somebody show me how to install HKS ground wire kit. This is a used one, it only comes with 6 wires and the gold plated circle thing. The hole in that circle is much smaller than the battery terminal, am I missing something here ? Thanks in advance.
Originally Posted by 05BlackTsx
Or you could post it like this:
05BlackTsx,
Basically you're going to connect the hub of that to the negative battery terminal, 1 of the short wires to the ground point (replacing the stock ground wire), and use the other ones to attach to ground bolts on most of the major engine components: block, trans, alternator... anything with power / electronics really.
From the picture above, looks like I'm missing some kind of adapter that connects the disc to the terminal ?
You should realize a kit like that is primarily for dress-up, don't expect it to provide any serious benefit. That said, installed tightly they can make an engine bay look sweet and also perform their function.
cycdaniel
12-17-2019 10:58 AM
BoricuaTL
04-08-2016 01:08 PM
Soul_Deamon
4G TL Problems & Fixes
11-02-2015 04:32 PM
