HELP!!!! 07 TL key fob !
Old Jan 13, 2007 | 11:25 AM
vthree's Avatar
2006 ASM tsx
omg. so i was impatient and i decided to take apart the 07 tl switchblade key. and cut up my key 1 that i was using since it was pretty scratched up... i put the immobilizer into the new tl switchblade key along with the key part of mine... however when i tested it before reassembling, the car wont start...
Old Jan 13, 2007 | 11:45 AM
KBraggs's Avatar
You should know what you are doing before you try this you know...
If you tried to start your car with an ineffective immobilizer, you may have disabled your vehicles electrical system which will put you in quite a bind...
Old Jan 13, 2007 | 11:48 AM
EuRTSX's Avatar
Ouch. This could hurt.
Old Jan 13, 2007 | 01:01 PM
DHCLK06's Avatar
have you tried using the Key 2 to see if your car starts? Hopefully it will. If so, get another Key 1, or check this thread - https://acurazine.com/forums/showthr...282#post656282 and have someone else do it. See what being impatient gets you?
Old Jan 13, 2007 | 01:02 PM
tony4311's Avatar
I am Ahab!
No he wouldn't. It doesn't turn anything off it just wont start. I've used the wrong key (two acura keys on my key chain) before on accident and its no biggie.
Old Jan 13, 2007 | 03:14 PM
KBraggs's Avatar
Umm, did you use a key that was CUT for your car without the programming, or just another acura key for a different car....that makes a difference you know...
If you use a key cut for your car and the chip is not programmed, you electrical system will be disabled until you can get it towed to the dealer.
Old Jan 13, 2007 | 04:58 PM
vthree's Avatar
2006 ASM tsx
i used my key 1.. sigh... 2 keys + valet key.. i used the 1st one.. and yes it was programmed for my car.
Old Jan 13, 2007 | 05:01 PM
acn684's Avatar
maybe u damaged ur chip?
Old Jan 13, 2007 | 05:09 PM
JTso's Avatar
That is false. I have a cut key without programming and it doesn't disable the electrical system. I use that key for performing compression tests so I don't need to pull the fuel pump fuse.
Old Jan 13, 2007 | 08:38 PM
moda_way's Avatar
Stupid question, but did you remove the immobilizer chip in the TL key?
Old Jan 13, 2007 | 10:01 PM
Spoon's Avatar
What does that even mean? Seriously though.
Old Jan 13, 2007 | 10:11 PM
JTso's Avatar
In order to correctly and safely perform an engine compression test, the fuel supply needs to be disabled so no fuel is injected down the cylinders during the test. Some choose to disconnect the injector plugs, and some choose to disable the fuel pump by removing the fuse. I choose to use a simple $2.00 cut key so the immobilizer won't function to energize the main relay to power the fuel pump. Since you have to turn the key to crank the engine anyway, why not disable the fuel pump at the same time? I consider it a simple, cheap and useful tool in the tool box.
Old Jan 13, 2007 | 10:47 PM
vthree's Avatar
2006 ASM tsx
ya i took the chip out of the tl.. i actually cut that one in half.. lol but igot all of it out.. on my chip. i like rubbed on it a little.. but not as much as i did the tl one.. i thought it was fine.. but i guess not? =( its covered in jbwelds now. =/ so i cant show u a pic. dammit.. sigh
Old Jan 13, 2007 | 11:05 PM
drunkenbuda's Avatar
Got Phó?
i am guessing its time for another tl key and have milled down and spend that extra cash to know it works
Old Jan 13, 2007 | 11:06 PM
KBraggs's Avatar
moda_way, didnt you recommend destroying the 07 TL chip while it is in the key rather than removing it?
Old Jan 13, 2007 | 11:23 PM
vthree's Avatar
2006 ASM tsx
ya i guess soo. but i just dont wanna wait forever.. i msg flbusa to see if he can help me out. and maybe just send him what i have and if he has a spare key portion. or if he'd give me a switchblade key for the price i found elsewhere.. but he hasn't responded yet. i feel like im a lil kid again being so impatient sighhhhh!!!! just wish there was a quicker way... really wish i could just call the guy
Old Jan 13, 2007 | 11:25 PM
hrj's Avatar
hrj
there is one guy selling his 2 keys at BM.
https://acurazine.com/forums/car-parts-sale-361/sold-fs-2-07-tl-switchblade-keys-mem-1-already-milled-precut-flbusa-tsx-tl-356296/
Old Jan 14, 2007 | 12:26 AM
buste2's Avatar
who dat lil kid?
one left now haha...hopefully he won't cut his finger this way..
Old Jan 14, 2007 | 01:27 AM
vthree's Avatar
2006 ASM tsx
haha ya was just my luck buste2 had keys and live like 2 mins away ha.
Old Jan 14, 2007 | 01:42 AM
Got Phó?
lol well now problem solved but one messed up tl key lol
Old Jan 14, 2007 | 01:48 AM
vthree's Avatar
2006 ASM tsx
hmm i got spare parts incase mine ever gets scratched now! hahaha
does anyone got the instructions for the locksmith and whatever else flbusa sent out?????
Old Jan 14, 2007 | 02:42 AM
Got Phó?
umm its just taking it to the dealer to get it cut to your key which any locksmith can do and having the immobilizer pair to your car. Call locksmiths and dealers around your area
Old Jan 14, 2007 | 02:48 AM
vthree's Avatar
2006 ASM tsx
i called the 2 dealers "nearby" lol and those punks quoted me 98 and 95$... seriously!?
Old Jan 14, 2007 | 12:47 PM
KBraggs's Avatar
That's over priced...just keep shopping around.
datadr
Mar 23, 2016 01:39 PM
soupi
14
Nov 15, 2015 11:15 AM
eastcoastguy
Oct 29, 2015 03:00 PM
DementiaPhuro
Sep 29, 2015 05:31 PM
malvothegreat
Sep 29, 2015 12:38 AM
