Tried installing the icebox this morning, everything went smoothly until I was about to close it up. No matter what I do, I can't get 3 of the screws holding airbox together to tighten up. Seems the holes out of alignment or the comptech box was just a little too thick. Anyone else experienced this? I don't supose there is a trick to this,is there?
Quote:
Helped a friend installed the icebox about a year ago.It was flushed..when did u get he icebox?Originally Posted by S2KDriver
if its the sleeves over the screws yer' talking about, for some reason, the CT engineering air box lid is a bit thick for the stock screws. you can just yank out that sleeve/sheath and use the screws.
that's what i did for mine; once you remove the sleeve/sheath-like thingy you'll be fine. i've had no problems with mine...
Yup, that's what I am talking about. Will give it a try.Originally Posted by 808havok_tsx
if its the sleeves over the screws yer' talking about, for some reason, the CT engineering air box lid is a bit thick for the stock screws. you can just yank out that sleeve/sheath and use the screws. that's what i did for mine; once you remove the sleeve/sheath-like thingy you'll be fine. i've had no problems with mine...
gistered User
Quote:
Look over the inside lip of your CT lid. My first lid was crudely routered-out, causing the lid to improperly seat over the base. I contacted CT–and they sent a replacement. Originally Posted by S2KDriver
https://acurazine.com/forums/1g-tsx-performance-parts-modifications-126/ct-icebox-lid-fitment-fix-726820/
It is also recommended to 'weather strip' the base.
https://acurazine.com/forums/1g-tsx-performance-parts-modifications-126/comptech-icebox-install-tips-more-679497/
Also, the lid screws can snap very easily. I replaced all mine with better quality, and slightly longer screws.
Tags
09, 2008, box, ct, engineering, enginnering, ice, icebox, install, installing, rsx, tsx, weatherstrip
