Follow-up - TB Coolant Bypass in the winter
Just wanted to have everyone post about doing the TB coolant bypass and it working fine.
So far I've been running mine in winter, in 10 F weather with rain/snow prior....
NO ISSUES AT ALL!!
Everyone sign in if you are running the TB coolant bypass in winter to put the issue to rest.
NO ISSUES AT ALL!!
Professional Newbie
this is good news guys
i've wanted to do this for a while, but was worried the car wouldn't start one morning and my dad would be all "You broke the car I bought you that used to work PERFECTLY FINE until you messed with it!"
Originally Posted by JTso
I didn't think it will have any problems after my "freezer" test.
Good test... DEFINITELY... but its also good to verify with the real world.
Drives With Hands
Originally Posted by moda_way
FYI, starting doesn't/shouldn't use the TB at all and neither does the idle, so you should be able to start the car and warm it IF there was ever an issue... but as you can see, none of us have had any issue.
Haven't had any problems here either.
Originally Posted by rmpage
It does on our car. DBW eliminates the idle air controller.
Good point, I forgot we don't have an idle control valve.
Master Graphic Artist
No problems here either. Went down to 6F for me.
To my understanding it has to be pretty damn cold for the throttle plate to stick. And I doubt that if it stuck without the TB bypass on a cold start with one it'll still stick... since I don't warm my car up before driving.
Drives With Hands
ABP TSX
Mine has been installed for several months, but then again it was 81 yesterday.
However, for the few times the temp has dipped below freezing (and a few days in the teens) I have experienced no issues.
Username 0
2G TSX Performance Parts & Modifications
23
09-28-2015 09:09 AM
